hei
Old Dec 7, 2002 | 05:34 PM
wicamaro84's Avatar
Car: 1988 camaro
Engine: 350 ci
hei
what is it? how would i go about telling if i have it?
Also is it better then i guess i would say standard?
Old Dec 7, 2002 | 05:54 PM
ede's Avatar
ede
high energy ignition, if you don't have points or direct ignition then you have hei. if you have a thirdgen f body you have hei.
Old Dec 8, 2002 | 10:49 PM
wicamaro84's Avatar
Car: 1988 camaro
Engine: 350 ci
only really reason im asking is because the motor came out of a 75-77 pickup 350 ci and i was buying plugs and they ask if i had hei but i got lucky they their both the same.
Old Dec 8, 2002 | 11:51 PM
darbleinad's Avatar
Car: 84 Trans Am
on the older HEIs, including some on 3rd gen f-bodies, the coil is in the top of the cap. i cant remember the year when they started using, HEI but it was the mid to late seventies...i think either 75 or 77 ( i am leaning toward 75),
Old Dec 9, 2002 | 07:41 AM
97-1LE's Avatar
Car: 87 Trans Am
Engine: Built 350 Cam, Headers
Transmission: 5 speed
75 was the first year for HEI .
Old Dec 9, 2002 | 09:19 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
HEI was GM's trade name for electronic ignition. It started in some 74 cars (I know, I had one, a Monte Carlo with a 400, we boughtt it in 77) and was in all cars starting in 75.
For a few years right at fist, they were telling everybody that they could gap their plugs at like .060"; so AC and others came out with plugs pre-gapped to that. After everybody's car went through a couple of rotors, we all got tired of that, and GM did too, so instead they started recommending .045". So that was the "difference" between the plugs.
Old Dec 9, 2002 | 11:10 AM
wicamaro84's Avatar
Car: 1988 camaro
Engine: 350 ci
cool thanks. Is there a way to tell if i have it or not?
Old Dec 9, 2002 | 11:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Is your car a late 74 or newer?
Does it have the stock distrbutor?
If yes, then you do.
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
