Battery or Alternator?
Old Dec 8, 2002 | 03:06 PM
SoSoFresh_SS's Avatar
Car: 1984 Firebird
Engine: 2.8L V6
Less than 5 months ago I purchased the most expensive alternator from Murray's and less than 2 weeks ago I bought a new battery. My car runs fine during the day time but at night when the lights and heat are on the blinkers dont work, my lights are dim, and to sum it all up, when I turn the car off I wont start again unless I get a boost. Is my alternator bad already? Or could something else be draining the battery? I dont have a stereo that requires excess power.
Old Dec 8, 2002 | 04:01 PM
ede's Avatar
ede
rebuilt alternators aren't known for long life and ones from discount stores don't have good history of lasting long. you need to get the system tested. m,ight be a loose wire or ground. have you looked at it or done any trouble shooting?
Old Dec 8, 2002 | 04:07 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
If you have a volt meter get the car started and test voltage, should be around 13.5 volts give er take .5, if you do not have a meter then, agian get the car running, disconnect the battery, most cars, with "good" alternators will stay running. HTH
Keiran
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
