New Road Demon Jr?
Old Dec 13, 2002 | 03:18 PM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
New Road Demon Jr?
Has anyone seen the new road demon jr?
If I were to buy a new carb should I get the road demon jr, road demon, edlebrock preformer 1406, or holley 4150/4160 ect.?
Can I run a spacer with the stock hood and is it worth it?
I want an Comp cams XE 262, Weiand stealth intake, mallory HEI, already have headers and 3' exhaust and a flowmaster, and I want to port and polish some L69 heads and use slightly larger valves(i dont know what casting these are).
What other mods could I do to a 305, .30 over, ect.?
Any suggestions or comments would be a great help, thanx:hail:
Old Dec 13, 2002 | 03:36 PM
felo72's Avatar
Buy a 350!
Honestly, it all depend on what kind of driving you plan on doing.
Old Dec 13, 2002 | 04:31 PM
I already have 2 complete 305s, the camaro and the trans am are daily drivers
Old Dec 13, 2002 | 05:12 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I asked a while ago on the review board, try a search. Demon carbs seem to be among the best.
Personally, I'm going with a Holley this time. No more Edel for me.
Old Dec 13, 2002 | 05:35 PM
gruveb's Avatar
Car: 1989 IROC-1
Not the edelbrock. I have almost the same set up as you do and mine edelbrock SUCKS!
Remember, nothing over 650 cfm. Demon has done a good job building a name for itself, but when a company gets "good" and then changes, it makes me nervous. I am still considering buying one though.
You know what you'll get with Holley, or at least a lot of other people do. They are a bench mark standard for the industry. Demon has applied 99% of the good stuff from holley and improved on it, but hten again 56.4% of all statistics are made up.
:lala:
Old Dec 13, 2002 | 10:38 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I just dumped my Edelbrock for a new Road Demon on my T/A daily driver. It was running great since I finished my engine/tranny swap, since this weekend I have another problem that is not related to the carb.
It has excellent throttle response, 4 cornor idle, it is A LOT easier to work with then the Edel. everything that is adjustable can be adjusted so easily. All you need to tune it is a flathead, a 5/8" wrench, and a long streach of road. It is also supposed to have some special gaskets that will keep your carb from losing tune. Plus it looks great.
My next choice would be a Holly S/A which is the same design with similar features and costs around the same.
Hope this helps a little,
Matt
Old Dec 14, 2002 | 03:25 AM
Thanks mark, gruveb, matt: just curious, what kind of problems are you having out of your edelbrock?
I think I will go with the road demon.
Old Dec 15, 2002 | 06:05 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i've heard of ALOT of problems with barry grant lately, the older stuff is ok, but there's been alot of substandard repairs and parts used in their newer stuff, thats why jegs and summit dropped them, they were getting as many returns for repairs as they were orders for new ones.
Old Dec 15, 2002 | 06:09 PM
gruveb's Avatar
Car: 1989 IROC-1
When did Jegs and Summit drop them? I just got the new catalogs and they are in there.
Old Dec 15, 2002 | 07:51 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
When I was getting my dyno done the guy at the speed shop noticed that the accelerator pump arm had a design flaw in it and said he heard that they recalled many of them and that most new ones should be fixed. Guess I got one that was on the shelf a while. I'm going to try to call BG to see what the deal is.
Matt
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Lbibb
May 5, 2016 12:00 AM
lewandom
Oct 1, 2015 08:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
