What is engine vacuum used for???
Old Dec 19, 2002 | 12:34 AM
Greasy Monkey's Avatar
The only things I can think of is power brakes, PCV, and vacuum advance. I dont have A/C, but plan to in the future so is vacuum important for that? educate me guys!! Thanks.
Old Dec 19, 2002 | 12:42 AM
89WS-6's Avatar
Some manual automatics use engine vacuum. I dont think thirdgens do, but the early ones (82-83) might have, someone educate me on this one too.
Old Dec 19, 2002 | 01:49 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Eng vacuum works quite well at getting air/fuel into the eng.
You need vacuum for the items you mentioned plus possibly some emission equip if installed.
The water control (heater) valve I believe is vac controlled if installed on your car.
Some older trannys (Turbo-400 for sure) need eng vac.
Cruise control on at least my car (82-Z).
Not sure abt the later models.
Some cars use it to lower folding headlights.
The heater-A/C controls use vacuum to direct air flow from defroster to floor and A/C vents if avaliable. Without the vacuum, the flapper doors are spring-loaded to their default position and direct air to the defroster ducts all the time.
Not real sure I understand the point of the question.
Are you planning a big cam?
Old Dec 19, 2002 | 11:20 AM
I was just wondering If I could run a xe268 cam in a 350 and have enough vacuum for all that stuff. I guess that should have been my real question, but I was also wondering what vacuum was even used for. thanks for the replys
Old Dec 19, 2002 | 11:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That cam in a properly tuned carbed 350 should give you plenty of vacuum for everything.
Old Dec 19, 2002 | 03:49 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i agree with rb... if all else fails just get a vac canister for your brakes.. shouldnt need 1 tho..
Old Dec 19, 2002 | 06:25 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
don't forget the coal canister (LOL, probably not important to you though).
Old Dec 19, 2002 | 09:56 PM
Thanks guys
Old Dec 19, 2002 | 10:50 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
man I ripped that thing out as soon as i got the car
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
