Windage Tray
Old Dec 20, 2002 | 06:00 PM
Acidtalons's Avatar
Windage Tray
How much horsepower is a windage tray really worth?
Old Dec 20, 2002 | 08:20 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Anytime you can keep the oil from adding additional weight/drag to the rotating assembly, your freeing up ponies, I can't say as if I ever remember seeing a dyno report on just adding a windage tray, but Hot Rod mag. always pushes the Mildon oil pan with built in windage tray and claims it's worth up to 20 hp, I installed the Moroso windage tray and oil pump block on my short block, requires a little grinding to fit inside the 7 qt. pan I bought though, did it free up some hp?...I don't know, but, it probably did'nt hurt anything though for the few measily bucks it costs. I kick myself in the rear for not getting the crank scraper, but oh well. Once this motors goes then we can add more goodies to the new short block later since this kinda stuff is reusable. Alot of guys install the lifter valley breather tubes to keep the oil from wrapping around the cam as well, by only letting the oil go through the front and rear oil galley. Need to have the bare block though, as you have to tap the bores to thread in the breather tubes.
BDR
Nov 7, 2015 03:05 PM
customblackbird
Oct 1, 2015 04:30 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
RW91B4C
Jul 17, 2001 08:53 PM
