estimate my e/t
Old Dec 20, 2002 | 11:08 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
estimate my e/t
hey gusy with wuts in my sig whats do you think i should be running in the 1/4? i am just curious cause my dad won;t let me take it to the track. he said i am gonna blow my trans and he will have to pay for it. well anyways wut u think? thanks
Old Dec 21, 2002 | 12:16 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
13.6 to 13.8 roughly.
Old Dec 21, 2002 | 03:10 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
sounds like a good guess, id say with decent traction and driving, that you could be closer to low 13s...let us know
Old Dec 21, 2002 | 03:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd guess 14 flat as it sits with the 3.08s, 13.5 with 3.73s
Old Dec 21, 2002 | 03:23 PM
zippy's Avatar
Engine: 5.3L
i don't believe a 3.08 or a 3.73 exists for a 9 bolt.
Old Dec 21, 2002 | 06:09 PM
Car: 89 Formula
Engine: Carbed 5.7
yea its 3.27 rear. yea i was thinkin 13.5 with traction
Old Dec 23, 2002 | 12:24 AM
Rancid87's Avatar
from the way you refer to it in other posts i'd guess right now it would probably turn low 15's or high 14's. in optimal tune i'd guesstimate high 13's.
Old Dec 23, 2002 | 10:01 AM
Car: 89 Formula
Engine: Carbed 5.7
so u are saying a 350 with a cam, intake, 750 carb, ignition, 3-angle vavle job on the heads will only pull less then a secound faster then a stock 350 tpi? i find that hard to beleive
Old Dec 23, 2002 | 02:58 PM
Rancid87's Avatar
it's not the fiddle but the fiddler.
Old Dec 23, 2002 | 03:29 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
preach on brother
Old Dec 23, 2002 | 03:53 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
LMAO, well if what the other guy said is correct and your car isn't running right, then yes it could run that.
I happen to "know" someone with a 350, 3:73s, Comp 268xe cam, full exhaust that ran a mid 15 with a carb.
It's all in how things are working.
BTW, I believe it was the carbs fault for those poor times..
Old Dec 23, 2002 | 04:24 PM
Car: 89 Formula
Engine: Carbed 5.7
true, but i am only 17 and i am still learning how to tune a carb, i built my whole car just about and i am just learnin how to tune a carb in right, so any input from the master fiddler would be helpful thanks
Old Dec 23, 2002 | 06:18 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
If you get all of gremlins worked out should definitely be a low to mid 13 sec. car........Just take to Atco on a thurs. night when your dad least expects it! lol
Old Dec 23, 2002 | 07:33 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
13.5 with traction. Sounds like a good setup.
Old Dec 23, 2002 | 07:53 PM
Car: 99 Formula
Axle/Gears: 342
I'm going to go with very high 13s.
Old Dec 23, 2002 | 11:15 PM
MdFormula350's Avatar
mid 13's is my guess
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
ws6transam
Jan 31, 2001 07:18 AM
