Flexplate for an 86 T/A 153 or 168 tooth?
Old Dec 29, 2002 | 07:42 AM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
What flexplate does my 86 T/A have? It's an 700R4 with an LG4
Old Dec 29, 2002 | 09:17 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
153 tooth one piece rear seal crank
Old Dec 29, 2002 | 09:41 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Correct
Old Dec 30, 2002 | 03:20 AM
will this work?
http://store.summitracing.com/partdetail.asp?part=99
Old Dec 30, 2002 | 03:29 AM
radiateu2's Avatar
flex plate
I have the flex plate you need it is used though if you want a new one look up enginekits.com and give them a call I got one for half the price of Summit
Old Jan 4, 2003 | 06:49 AM
do I need internally or external balanced?
Old Jan 4, 2003 | 07:04 AM
radiateu2's Avatar
flex plate
The flex plate that came off of my one piece seal crank had a bat wing shaped weight on the flex plate. I am sure they call this externaly balanced. It compensates the crank for its design for the one piece seal. I notice when I went to a two piece seal crank the flex plate I bought didnt have the counterweight on it. Incidently the weight is installed closest to the crank, if my memory serves me correctly.
Old Jan 4, 2003 | 07:07 AM
thanks , I did a little searching after I posted and its ext. balanced.
codeysabatini
Nov 10, 2015 04:07 PM
2012sergen11
Oct 13, 2015 07:38 PM
gord327
Oct 3, 2015 01:25 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
roysatikas
Sep 7, 2015 08:08 PM
