Shipping out a motor
Old Jan 1, 2003 | 12:39 PM
Iroc n roll's Avatar
Not sure where to put this one so here goes. I'm shipping someone a block. It's too heavy for UPS or USPS. How the hell do I ship this thing. Has anyone here ever done it? I'm in CT so if you can recommend someone around here too that would be great.
Old Jan 1, 2003 | 01:35 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
mailboxes etc should be able to tell you who can ship it.
Old Jan 1, 2003 | 02:36 PM
Z28DJP1987's Avatar
You will have to ship it by truck Company, check your Yellow Pages
for info and call for rates. Also the rates depend on whether its a interstate shipment.
Old Jan 1, 2003 | 04:47 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I'm currently doing the same sort of thing, a guy in Michigan is supposed to buy my race preped 700r4-we'll see-you'll have to call trucking/freight companies-call as many as poosible as prices vary greatly. They'll ask you the weight of the shipped item, keep in mind that you will have to crate this item (see photo) so the company can move stuff around w/ a pallet jack or fork truck. What class the item is, the tranny complete was a class 85 don't know what a block would be. Are you going to drop it off at the companies terminal or are they picking it up from your house, same as the guy on the other end, all my companies residential fees were around $50-55 per residential visit. I'm dropping it off at the terminal as they're only 20min away and the company has another terminal 30min from this guys house so he saved $110 right there on a 225lbs package. Prices were from $91.43 to $172.48 +3.5% for fuel, and it's only going from central IA. to Detroit. They'll give you a quote number, keep it, so when you ship it they'll have all your info on file already.
Old Jan 1, 2003 | 08:57 PM
Vader's Avatar
Is it a bare block? Just the case alone may be under the wieght limit for FedEx, since they have a higher weight/girth allowance than those wimps at UPS. Roadway/RPS will also do regular motor freight with residential pickup/dropiff. I'm sure there are many others. One I would avoid is Holland Freight - they don't seem to be very customer oriented and seem rather slow.
Old Jan 1, 2003 | 09:09 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
FedEx ground residential services still have the annoying 75# weight limit, it increases to 150# if you ship to a business instead of a home.
I use FedEx Freight for overweight packages/pallets.
http://www.fedexfreight.fedex.com/default.jsp
Old Jan 2, 2003 | 07:02 AM
70GTO's Avatar
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
I'm in the process of sending a complete 350 TPI engine from Illinois to Washington DC. It is gonna cost $305.00
to ship it by truck (Conway freight).
I secured it to a pallet & boxed it in "what a time consuming & royal pain in the rear !!" , now I'm ready to deliver it to the trucking dock wher they will unload it from my truck with their fork lift & then deliver it to the buyers address.
The others are right, Look in the yellow pages and call the various trucking freight lines in your area. Ask them what they require as far as boxing, pick-up & delivery and shipping charges.
Bruce (70GTO)
Old Jan 2, 2003 | 09:57 AM
Morley's Avatar
Try Fed-X ground shipping services. I sent a pair of cast iron heads through them (102 lbs) and it was only $47. The person at the ground ship counter told me there was no real weight limit on ground shipping, however you may need to ship to a commercial address or have them pick it up at the freight terminal.
Old Jan 2, 2003 | 11:21 AM
ede's Avatar
ede
ABS (i think) has the best rates for motor freight. they give special rates for infrequent shippers that use their web page and drop off and pick up at a terminal. i have the link saved on my puter at home but not here
Old Jan 2, 2003 | 01:33 PM
David Petersen's Avatar
A little bit off the subject but does anyone know how much a fully dressed (all accessories) L98 weighs? Also a T-5 tranny?? I am going to list these two for sale but need wieghts for shipping quotes.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
madsv1000
Aug 20, 2015 06:45 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
NBrehm
Aug 5, 2015 07:57 PM
