How do you check timing in a TPI'ed vehicle??
Old Jan 5, 2003 | 09:01 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Like the post says....how do you check timing in a TPI'ed
F-body??? I have the Haynes manual but as usuall that book doesnt help me at all!!! Doent ever buy a Haynes book..I got mine for free so i got an excuse.
Old Jan 5, 2003 | 09:44 PM
Vader's Avatar
Old Jan 6, 2003 | 05:19 PM
Brian'sIROC's Avatar
You need to unplug the connector on the passengers side firewall harness. It's tan w/ a black stripe. Then connect the timing light to #1 wire and battery terminals
Old Jan 7, 2003 | 09:08 PM
thanks Brian and Vader for the info...just need you guys to answer a few more DUMB questions and I'll be able to set the timing...
1) Which cylinder is #1??? If im facing the firewall is it the one closest to my left hand or the one closest to my right???
2) What should timing be set to????? 5 degrees BTDC????
TIA..
Old Jan 7, 2003 | 09:23 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
The odd numbered cylinders go from 1 to 7 on the driver's side and ascend in order going from the front of the engine towards the firewall; the passenger's side does the same thing, except that it has all of the even numbered cylinders.
Or, to be more visual...
{ FIREWALL }
..(8).............(7)..
..(6).............(5)..
..(4).............(3)..
..(2).............(1)..
{ FRONT OF ENGINE }
As for what the timing should be set to, there should be a label attached to the underside of the hood towards the front that says what the timing should be set to.
Old Jan 7, 2003 | 09:28 PM
holmes677's Avatar
is retarded to the passenger side of 0 degrees if youre looking at the front of the engine or the driver side?
Old Jan 7, 2003 | 10:10 PM
sancho's Avatar
holmes677: I should know this... I'm pretty sure that advanced is towards the passenger's side and retarded is towards the driver's side. Either way, it should say on the timing cover (positive numbers are advanced and negative numbers are retarded).
Old Jan 8, 2003 | 08:27 AM
Vader's Avatar
When viewed from the front, the engine rotates clockwise. You can figure out the rest.
Old Aug 12, 2003 | 05:25 PM
well....I finally decided to time my engine.... yeah I know this post is at least 6 months old. I only drive the car on weekends and Im always getting side tracked with other car projects...
Anyway.. I hooked up my timing light to the battery, connected the lead to #1 cylinder and the timing mark jumps a lot. Yes..I did disconnect what I believe is the E.S.T. Connector. Is the E.S.T connector different colors for different years because mine is just Tan...no stripe. Is this normal for the timing mark to "jump around" a lot or does this mean the chain has a lot of play in it???
Dan
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Sanjay
Aug 12, 2015 03:41 PM
