Rear Wheel Hp
Old Jan 9, 2003 | 12:50 AM
305iroc's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.42's
Rear Wheel Hp
How much hp do you think my 305 tbi auto trans will put to the rear wheels? I thinking well below 150 hp. I watched a mustang (89 5.0) put 190 hp to the wheels today. I thought I was going to see a little more than that maybe 215. I have a friend with a RX-7 That put 410 to the wheels. The thing pulls 10.6 in the 1/4. I'm going to dyno my car just to see. Its free so why not. Cars mostly stock excepted exhaust which isn't worth anything but a cuple horses.
Old Jan 9, 2003 | 03:01 AM
NTChrist's Avatar
Depending on the mileage, state of tune, I think you're about right.
Check out the TBI board for info on how to pad that # a bit.
Old Jan 10, 2003 | 09:19 AM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
The January 2003 anniversary isue of Hot Rod Magazine has a neat formula to figure rear wheel H.P.. All you need is an accurate 1/4 mile mph number.
The formula is this
hp= (mph divided by 234)3 x weight.
mph divided by 234, that number cubed times weight.
My basically stock 305 tpi figures out around 165hp at rear wheels.
H R says the formula is pretty accurate for cars from 9 - 16 sec 1/4 miles and under 4000 lbs. They gave it an accuracy rating of 4.5 out of 5.
Have fun with it
Old Jan 11, 2003 | 12:57 AM
305iroc's Avatar
Car: 91 Z28
Axle/Gears: 3.42's
Thanks, I'll remember that. 165hp at the wheels sounds about right for a 305 tpi.
Old Jan 11, 2003 | 08:37 AM
Vader's Avatar
That's odd, since the factory stated it at 190, IIRC.
Old Jan 11, 2003 | 08:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
TBI motors were 170 HP rated, IIRC; I'd expect to see something in the 135-140 RW HP range for a bone-stock one.
For comparison, a stock 305 TPI usually puts about 165 HP to the wheels, out of its rated 205-210 crank HP.
At "dyno day" here locally a few months ago, a bunch of the Mustang owners looked kind of glum when my 305, with its stock Q-Jet carb and intake and all emissions devices installed and operating in California emissions trim, put 208 HP to the wheels.... poor guys, I just hated it for 'em
Old Jan 11, 2003 | 10:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The way i've been figuring out *approxiamte* RWHP is just the flywheel HP minus 25 percent (or FWHP x 0.75)
its usually fairly close (within 10hp), but rarely bang-on
Old Jan 13, 2003 | 08:21 AM
Engine: 305 tbi
Reading the whole article in H.R. that formula is good within a percent or two. If you've got a weight slip and a time slip you've got your rear wheel h.p
Old Jan 13, 2003 | 08:41 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
I run a "dyno day" twice a year for the members in Ontario, and one of the guys has a 1988 Camaro with the 305 TBI. He rebuilt his motor and blueprinted it, and he managed 155 RWHP. My little LG4 with a couple of mods only managed a weak 151 RWHP. Since then I have added headers and a dynomax cat back. Also planned is a cam swap. The "peanut cam" is the weakest part of the 305. In order to make any HP, a new cam is in order. Good luck at your dyno session, just don't be too disappointed if the numbers aren't what you hoped for. I see it all the time, guys thinking that their mods are going to create huge amounts of HP, only to find a minimal gain. I, myself, included. It cost money to create any real HP.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
