gettting at IAC (#*^$
Old Jan 13, 2003 | 07:41 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
how the f do you guys get to your IAC? I even removed a couple things but i cant get to it. cant get a wrench around it-its in such tucked away place.
any tips? tools?
Old Jan 14, 2003 | 12:15 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Messing with that IAC is a pain in the @$$. Trust me. I have had serious idle issues with my car. I have had nothing but trouble working on that damn thing. Granted my level of experience in such matters was very limited before tearing that mess apart. TPI engines suck to work on and troubleshoot. Unfortunatley I have no real usefull information for you.
Old Jan 14, 2003 | 10:45 AM
Vader's Avatar
Diggler,
According to your web pages, the car has TPI. That makes a bit of difference.
I don't have that much trouble accessing the IAC motor on mt '86 engine. If you remove the air intake bellows and upper alternator bracket, there is plenty of space.
Old Jan 14, 2003 | 11:44 AM
Diggler86's Avatar
Car: 86 TA
yeah, i didnt want to remove that upper alternator bracket, but looks like i may have to... may be easier in the long run than trying to get at it otherwise... thanks vader...
87ws6- i replaced the iac in my old 87 (took me FOREVER) and it made a world of difference. the original was so old it was breaking apart.
Old Jan 14, 2003 | 08:20 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
Recently replaced my IAC. Now I have a high idle problem but that's another issue.
To remove the IAC without destroying anything I found the best method was to remove the throttle body. I bought a throttle body gasket kit from a parts store, cleaned up the throttle body while it was off and put it all back together. No stalling with the AC anymore...
Old Jan 15, 2003 | 11:12 AM
Diggler86's Avatar
Car: 86 TA
theres an idea. thanks.
Old Jan 15, 2003 | 01:06 PM
lopoetve's Avatar
What would happen if, say, the IAC pintle on a TPI car was stuck all the way in (valve closed, no air flowing)? Would it immediately die every time it tries to idle?
Old Jan 16, 2003 | 05:29 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
I would think that would depend on where your minimum throttle position is set (screw on the driver side of TB). Mine will run with the IAC fully extended, but then mine doesn't idle correctly anyway.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
