Anyone else have Dart Iron Eagles?
Old Jan 14, 2003 | 06:04 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I installed my intake yesterday. I bought the intake gasket set that Dart listed (FelPro 1204).
I noticed that the water ports don't match up as well as I thought. The port on the head is higher than the hole in the gasket. It still matches up, but only half the upper part of the gasket is touching the head.
Is this a "take the intake off and do it again" kinda thing?
Old Jan 14, 2003 | 08:04 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I'm running the 180's port matched to a 1205. The water ports seem to sit about 1/10" higher or so for some reason. Even with that being said I haven't had any leaks or anything in the past 2000 miles. I wouldn't worry about it too much.
Old Jan 14, 2003 | 08:09 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Cool. I have the 180's also. I'm glad to see that you haven't had any leaks. That being said I'm gonna go put more stuff back together.
thanks!
Old Jan 14, 2003 | 10:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did you guys have a lot of casting flash on your 180's?
My friend bought the barecastings but was pretty bummed about the amount of cleanup needed.
Old Jan 15, 2003 | 12:18 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I bought my Dart 180's assembled. They were clean as could be. I still blew them off with the air hose just in case there were metal shavings hiding.
Old Jan 15, 2003 | 08:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's interesting, I wonder if they ship a bit "unfinished" when bare? We'll have to give'em a call and find out, thanks.
Old Jan 15, 2003 | 09:35 PM
Car: 86 Cutlass
I bought mine used off of a guy, so I'm not sure how they originally came, but the ports were kinda not the smoothest. I'm not real sure how to describe it. There was some flash in the ports that I cleaned up, and compared to the GM castings they seemed to be rougher. I still like them a lot and they seem to work a lot better than what I had on there.
Old Jan 16, 2003 | 10:28 AM
Damon's Avatar
They're machined well where it counts: just before and after the valve seats. The port throats are a bit rough but that's not really a flow-critical area. I did smooth the transition from the machined area to the port throuat slightly as there was a little "lip" there where stuff didn't line up perfectly. My water passages don't line up perfectly either, but never a problem sealing them up.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Nervous2
Oct 8, 2015 10:53 PM
86z89iroc
Oct 5, 2015 01:04 PM
mfp189
Sep 27, 2015 09:25 AM
F-body-fan
Sep 17, 2015 12:16 PM
