Changing the front oil seal
Old Jan 20, 2003 | 09:09 PM
llvll4l2c91350's Avatar
Hey guys my front oil seal has blown. It doesn't look like a difficult task to replace but I wanna know if I need a special puller for the pulley or the damper. Or any other tips anyone can share about this job. thanks.
Old Jan 20, 2003 | 11:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pulley, no. Damper, yes.
And an installer to put the damper back on.
Old Jan 21, 2003 | 06:08 AM
ede's Avatar
ede
i use a slide hammer to pull the seal, makes it real easy and quick to get out.
Old Jan 21, 2003 | 06:30 AM
ctandc's Avatar
Slide hammer works, as does a "seal puller" which you can pick up cheap for like $5 or so.
Also, MAKE SURE, you heed the tip about using the RIGHT puller for removing the harmonic balancer, and the RIGHT installer to put it back on. This is one area where cheap tools, are just that...CHEAP, and likely to damage something.
Don't hammer the thing back on...plenty of people will tell you they've done it a hundred times without problems, but if you've seen a crank get bent from hammering the balancer on, you'll never do it again.
Just my highly inflated 2 cents
HTH
Old Jan 21, 2003 | 07:14 PM
Hey thanks for the tips. Honestly I thought about hammering that thing in gently but I don't want to damage the crank. A little problem could turn into something huge. Looks like I will have to add another tool to my collection. I saw a damper puller at the parts store today but no installer. So even if I get this tool I won't be able to finish the job. I believe there is a tool that combines 'em both. I'll call the Snap-On truck tomorrow to check with them. Would rather get that than buy two seperate tools.
Old Jan 22, 2003 | 12:25 PM
Vader's Avatar
Stop waiting to pay the Snap-Off dude. Got to your local hardware store (a REAL one, not Home Depot) or fastener supplier and get a 6" section of 7/16" 20 Grade 5 or better threaded rod and two (or more) mating nuts. You may have to get a length of rod (3-6') like I did, but for less than ten bucks you have a lifetime supply of balancer installers.
Thread the rod until it bottoms in the crank snout, start the hub, install a washer and nut, and zip it in place. If the rod isn't backing out easily, thread on the second nut, jamb the two together, and zip it back out.
Or you could wait a week for the tool truck dude to order it, pay eleventy-seven times as much, but get a really nice overpriced case to store the parts in and take up more space in your tool cart.
Old Jan 22, 2003 | 01:48 PM
ctandc's Avatar
Yup....... I agree with Vader.
I'm just not one to share "homemade" adapters / tools / solutions that I've used....it's my luck that someone will try it, break something, be related to a lawyer, sue me etc.
But that's just me. Mr.Murphy and I have know each other waaayyy too long.
Oh yeah... don't forget, that sometimes, ESPECIALLY aftermarket balancers, tend to sometimes need a little "clearancing" to fit on the crank snout without being Superman. The last Fluidamper I used, I ended up sanding the inside of the balancer to keep from breaking anything...could be just me though.
Later
Chris
85 IROC
"Remember men, your weapon was made by the lowest bidder..." A favorite NCO of mine, minutes before my first active jump.
Old Jan 22, 2003 | 10:15 PM
Thanx guys. I never thought about doing it that way but if it works I'm gonna save me an *** load of money. It sux having to pay for a tool that you're not gonna use that often. I'll work on it this weekend and post the results.
Old Jan 25, 2003 | 03:19 PM
Just finished changing the oil seal. Everything went well. The hardest part had to be finding the 7/16 rod. Very few places seem to have it. Went to Napa and they had a 3 foot section. I cut off about 5 inches and slowly turned the nut to push the damper in place. About halfway through it got really tight but I managed to get it in place. Just ran the car for about 10 minutes and everything seems fine. Thanx for the suggestions!
Old Jan 25, 2003 | 09:14 PM
Vader's Avatar
...and now you have an extra half dozen hub installers, and still paid less than the Snp-On dud would have charged for one. No pretty plastic case, though.
Old Jan 25, 2003 | 09:34 PM
lol nah no case, but if you got any tips on making my own so I can put my new installers in it, lemme know.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
