help!!!,desktop dino users
Old Jan 21, 2003 | 10:27 PM
THAT T/A GUY's Avatar
help,i need to know what aprox numbers would i get from a 350 with stock tpi heads,a comp cams 280H cam(230,230 at .050")(.480 lift)it ain´t a roller cam,can i use it with my engine?i also think about a set of 1.6 rockers on my exhaust valves,would it be better with them on both intake and exhaust?,the whole combo would be,(if possible) as written below:
1990 350 TPI
stock heads
weiand "stealth" intake
holley 750 vacuum secondaries
1.6 rocker arms
comp cams 280H cam
rhoads variable duration lifters
maybe oversized valves(2.02,1.60)
shorty hedders
2.5 inch dual exhaust with an h-pipe
flowmaster delta flow 40-series mufflers
i think it pretty much is it,but i have some doubts:
can old style heads parts(above)be used on centerbolt heads?
can this cam(hidraulic flat tapped)be used on this block?
what mods are needed to install an old style intake on these heads?
is all what i´m askin just plain ?
i hope you can help me with this as im really new to chevy engines(never owned centerbolts before)
thanks for all,Paul
p.s. any suggestion are reallty apreciated for a carb´d 350.
Old Jan 21, 2003 | 11:01 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Sorry, can't model the Stealth Ram intake
Old Jan 21, 2003 | 11:06 PM
it ain´t a ram intake,it´s like the performer rpm from edelbrock,wich i could as well use.
Old Jan 21, 2003 | 11:21 PM
Engine: 305-4v
OK, here it is. Much better than the original L98. If you add oversized valves or 1.6 rockers you might gain 10 hp or so.
Oops! I used the TPI intake. Here it is with the dual plane. Not much different.
I think a dual pattern cam like the Comp XE 262 or 268 would give you more power.
Old Jan 21, 2003 | 11:27 PM
Engine: 305-4v
I just ran the 262 and 268 but they give less power.
L98 heads respond very well to a good port and polish job. Probably add 20 or 30 hp.
Old Jan 21, 2003 | 11:30 PM
like i said before,thanks a LOT!! sitting bull
I was hoping a little more power but whit this i think i should be able to defeat most 5.0´s and imports moving arround here in mexico(stock non turbo supras,mazda mz6´s,honda civics,and all those **** cans).
Paul
Old Jan 21, 2003 | 11:31 PM
Engine: 305-4v
Paul
Via condios, senor!
Old Jan 21, 2003 | 11:37 PM
he he,that´s written "vaya con dios señor!"
see ya.
Old Jan 21, 2003 | 11:41 PM
Engine: 305-4v
Night rider327
Oct 9, 2015 09:25 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Night rider327
Sep 25, 2015 04:47 AM
Night rider327
Sep 25, 2015 04:19 AM
gt4373
Sep 24, 2015 11:34 PM
