Which head-gasket: Fel-Pro or stock-GM?
Old Jan 23, 2003 | 06:29 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
Subject pretty much says all...
I've got to put new head-gaskets on my L98, and I'm curious about what I should get. I know that everybody and their cousin uses Fel-Pro; I know that Fel-Pro does some "tricks" with the size of the coolant holes in the gaskets. However, I figure that GM probably knows their engines better than anyone else; the GM gaskets that were on there lasted >~160K miles. Personally, I'm trying to go for reliability/longevity here, and I'd love it if I could get another 160K miles out of this engine after I get it running (it's been rebuilt)...
Old Jan 23, 2003 | 07:14 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i use the GM 14096405 it is .028" thick. raises compression ratio about .5 thinnest composite gasket you can get.
Old Jan 24, 2003 | 11:59 AM
Damon's Avatar
I have always used Fel Pro and they are good gaskets. I've never popped one if used on a flat deck with flat heads. Not even on nitrous.
However, I'm trying the GM gasket mentioned above in my blown 383 for the first time. SHould have it running again in a few weeks.
Old Jan 25, 2003 | 04:31 AM
titeride85's Avatar
Fel-Pro. Always Fel-Pro.
MY87LT
Aug 17, 2015 08:43 AM
bad@ss89camaro
Aug 23, 2002 11:17 PM
Der91Z
Jun 24, 2002 07:04 AM
Slow89Iroc-Z
May 6, 2002 12:32 PM
Changa2
Jul 24, 2001 10:34 PM
