64cc heads on LB9
Old Jan 25, 2003 | 03:55 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
64cc heads on LB9
What im trying to do is buy 350 parts and put em on my 305 until i have enough $ to get the block and or blow up the 305. Just wondering how a set of 64cc heads wit 2.02 / 1.60 valves will do on a 86 LB9 motor?
Old Jan 25, 2003 | 04:40 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Those valves are way too big for that bore.
Old Jan 25, 2003 | 06:46 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
i hear 60cc is max u want on a 305...
Old Jan 25, 2003 | 07:22 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
yea, 350 heads will lower the compression on your 305......
Old Jan 25, 2003 | 08:28 PM
iroc22's Avatar
They will work great on the LB9. The compression ratio will suffer slightly, but the effects of the 2.02/1.60 valves over the stock 1.84/1.5's will give you a nice boost in power. As long as you keep your camshaft lift under .600" you will be fine for valve-bore interference.
Old Jan 26, 2003 | 12:58 AM
d4nk's Avatar
Car: 86 T/A
Engine: 383
wha bout if i were to get the world products tourqer 305s, what would they do on a 350 block with the 58cc chamber. What kinda restriction are the 1.94 / 1.60 valves gonna be on a 350? Is it gonna bottle neck it or would i be better off gettin a 350 longblock with the stock heads?
Old Jan 26, 2003 | 03:39 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
No, the World heads will work very well with a 350, too. Do some bowl blending, though, before putting them on. That will probably add 10 hp or so.
Talk to five7kid. He's here all the time and uses the SR heads himself. He did some minor porting and got good results
He lives in Littleton--maybe you're neighbours?
Old Jan 26, 2003 | 04:40 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
MATE DO WHAT I DONE,,,just keep driving the 305,,,get a junk 400,,,recondition it,,put a set of vortecs on it,,,,its a cheap setup,,,,buy a small cam,,,intake ,,etc ,,,,its cheaper than pulling parts off and on the 305,,, ,,mine has 8.75:1 comp ,,i know,it will run on any pump gas,,, has dished pistons and 64cc heads,,just get a pro rebuild,,,on the above ,,,,,its cheap,,,,,my engine will go in in 3 weeks ,,,i think it will run ok,,,,you can do the same,being in america,,,parts are everywhere,,AND DIRT CHEAP,,,,
Old Jan 26, 2003 | 01:54 PM
iroc22's Avatar
I run the S/R 305 Torquers. From the factory they can be cleaned up a lot. I did a minor port/polish job and they work quite well over stock castings. The 1.94/1.50 valves will not be a major restriction to the breathability of the 350; but the 58cc chamber will bump up the compression a bit, which may or may not be a good thing.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
