anyone install a Tommy Johnson Mini STarter?
Old Feb 3, 2003 | 08:55 AM
trd51398's Avatar
Hey everyone
I did a search on this already and couldn't find anything. I have an 88 iroc with the L98 350. I removed the old starter already and have the mini starter ready to be put it. Is there anything I need ot know when putting this one in? Or can I just bolt it up with no problems? ANy help would be much appreciated.
Old Feb 3, 2003 | 12:26 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I've done mine. The only thing you're going to have to watch for is getting the correct spacing between the pinion gear and the flywheel.
I don't remember the spec (should be in the instructions). I used a drill bit.
big weight difference huh
Old Feb 3, 2003 | 12:30 PM
trd51398's Avatar
hey thanks for the reply...
there is a huge weight difference and much easier to get past the exhaust. They say the spacing has to be 1mm, how do I check that? Thats the one real problem I have, other then that it should pop right in.
Old Feb 3, 2003 | 12:39 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I used a drill bit 1mm thick (if that's your spec) placed between the pinion gear (extended) and the flywheel. Just pull the pinion out and see if the bit fits. Too loose or Too tight = adjust again.
Getting the spacing right was what took most of my time.
Old Feb 3, 2003 | 01:08 PM
trd51398's Avatar
thanks for the quick reply...
I got what you are saying about putting the drill bit in there, but I am still not quiet sure on how to see this? Sorry if it sounds stupid. do I put the bit in the pinion gear and then place the whole unit up there?
sorry to be a pain
Old Feb 3, 2003 | 01:22 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Mount your starter
Pull the pinion gear out by hand till it meshes with the flywheel
while holding the pinion gear there see if the drill bit fits between the pinion and flywheel.
Adjust your starter as necessary
Old Feb 3, 2003 | 02:57 PM
trd51398's Avatar
one last question I hope, do I have to remove the black piece infront of the starter that protects the flywheel?
I am so confused
Old Feb 4, 2003 | 12:38 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
it'll make it easier to check your spacing if you do. it's only held up with 4 bolts.
Old Feb 4, 2003 | 01:01 PM
trd51398's Avatar
thanks again for all your help...
I hope I haven't been too much of a pain..
Old Feb 4, 2003 | 01:05 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
That's what we're here for.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
