87' 305 TPI Running like Crap
Old Feb 3, 2003 | 02:28 PM
87z28TN's Avatar
Car: 1987 Camaro Z28
Please Help me guys.
I have an 87 Camaro Z28 with a 305 TPI, and the car is running like crap. First the cars is nearly impossible to start when cold. She idles iratically, misses throughout driving range, and is very hesitant. Also to make matters worse, when the pedal is depressed to the floor, the car surges really bad and feels like it is going to jerk itself in half. Also the lifters rattle pretty bad when the pedal is pushed to the floor. Any ideas guys, I would really appreciate an idea on where to start.
Thanks in adavance !!!
Old Feb 3, 2003 | 02:43 PM
blue86z28's Avatar
lol
Time for a rebuild!
Old Feb 3, 2003 | 02:46 PM
87z28TN's Avatar
Anyone with some real advice?
Old Feb 3, 2003 | 04:57 PM
87z28TN's Avatar
Please Guys, anyone have any ideas?
Old Feb 3, 2003 | 05:05 PM
joshp14's Avatar
timing, tune-up, check all sensors, throwing any codes??
Old Feb 3, 2003 | 05:08 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
is your timing way off? Are all the spark plug wires connected tightly? Sounds to me like you just need to whip out the timing light and get that motor in sync.
Old Feb 3, 2003 | 05:25 PM
87z28TN's Avatar
No Codes
I checked last night and it is not throwing any codes. I plan to try to time it tomorrow. What sensors would you recommend checking? Thanks for all the help!
Old Feb 3, 2003 | 05:36 PM
rezinn's Avatar
Change the fuel filter and the oil recently?
Old Feb 3, 2003 | 05:43 PM
joshp14's Avatar
MAF sensor, MAT, IAC, TPS...but if you arent getting any codes then i dont think its a sensor. check fuel pressure and timing and let us know how that turns out. Also like rezinn said, check fuel filter.
Old Feb 3, 2003 | 05:51 PM
Soulrev's Avatar
Honestly I don't see any reason why it would be doing that besides the timing.. Unless, however, you have a LOT of condensation in your gas tank and there's a lot of water in your gas lines.. My F-150 has a slight leak on the top of the gas tank and sometimes (usually in the spring when it's humid, but happens a lot in the winter also) it will run extremely rough, just like you explained there. But it will go away after about 5 to 8 minutes.. Just because of the water that got in there. It's most likely one of those two things.
Old Feb 3, 2003 | 06:32 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Sounds Like what I had ....Timeing!
Old Feb 4, 2003 | 01:20 AM
lopoetve's Avatar
Timing and Sensors. My 87 TPI had those problems. Rotor, Cap, and plugs/wires too.
Oh, and check for carbon buildup.
Old Feb 8, 2003 | 06:00 PM
87z28TN's Avatar
Hey Guys
Thanks for all the help that you all have given me thus far. I have completely tuned the car up doing the following:
Plugs
Cap and Rotar
Fuel Filter
Oil Change
Air Filter
EGR Valve
The car is running alot better, but now the SES is throwing code 34. Any ideas as to what to do next???
Thanks in advance!!!!!!!!!!!!!!!!!!!! :lala:
Old Feb 11, 2003 | 07:40 AM
87z28TN's Avatar
She's Running Like New
I found the code decoder on the main page, and bought a new MAF Sensor for my Z28. She is running perfect now. I want to thank all the guys who helped me diagnose my car.
:hail: Thanks Guys
Old Feb 11, 2003 | 09:01 AM
Vader's Avatar
Another ThirdGen.org success story. Now if we could only get Gerhardt Schroeder, Jacques Chirac, and his buddy Putin to log in, we'd get them straightened out, too.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
