anyone run their plug wires between heads and headers?
Car: '87 Camaro LT
Engine: 355 L98
...as opposed to on top of the valve covers. i think it would help clean the engine bay up a lot but i'm worried about excessive heat. anyone done it? did you use some kind of sleeving on the wires?
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I know that Thermo Tec sells this things to protect the wires. Whitout them i guess whe wires would melt.
But your right that it would clean up the engine bay.
Car: 1990 GTA
Transmission: manual/t56
I did on my camaro but I used thermal sleeves on the plugs and header wrap on the headers. Also I used cut to lenthplug wires so I had plenty of lenth to work with. It really does clean the engine up.
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I run mine between the headers and the heads.
They're MSD Super Conductors and I used MSD Pro Clamp wire separators. I also cut them to length so they wouldn't burn on the header.
Originally posted by 25THRSS
What do you mean between the heads and headers exactly, any pictures?
They go from the distributor, down around the back of the cylinder head, and then between the headers and the heads. I routed the wires while the motor was on an engine stand... so that definitely made it ALOT easier to do. Trending Topics
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
