Will a Performer Rpm intake Fit?
Old Feb 10, 2003 | 02:12 PM
z28redline's Avatar
Car: 1986 Camaro Z28
Engine: 305 lG4
Can you use a stock q-jet with a performer RPM intake manifold? Will it fit under the stock hood of an camaro?
z28redline
Old Feb 10, 2003 | 04:24 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I think the Qjets are spreadbore and need a spreadbore type manifold. You could get the spreadbore manifold or an adapter from spreadbore to squareflange but that would increase the height. I have a RPM manifold and 1406 performer carb and it all fits under the hood of my TA. I doubt it would with an adapter though. Maybe someone can varify this for me because its been a while since I've worked with Qjets.
Old Feb 10, 2003 | 04:39 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
hey ive got the performer and i have no clearance problems with a 1inch spacer and a 14X3 air filter.
Old Feb 10, 2003 | 05:02 PM
Rob116's Avatar
Car: 1986 Z-28 Camaro
Engine: 355
Search would have definitely got you the answer. Anyways, you need 1407, Performer RPM Q-jet (which is a spreadbore version), with a 1.5" drop base 3" air cleaner. Edelbrock sells those too.
Old Feb 10, 2003 | 06:57 PM
No4NJunk's Avatar
Pull the rat out of your ***!! The search is down right now because of server problems. Guess If you could read then you would have known this.
Old Feb 10, 2003 | 07:28 PM
z28redline's Avatar
Engine: 305 lG4
So there is no way to get a performer rpm to fit with a stock q-jet unless you have an adaptor plate, But then it would be 1.4" higher then the stock setup and wouldn't fit under the hood. Is there any one who was tried this? I just really want to be sure there is no hope.
z28redline
Old Feb 10, 2003 | 08:36 PM
RICHRAD's Avatar
Haaaaaa!! Ha! ....Thanks No4NJunk... That "just search it does get old anyways
Old Feb 10, 2003 | 08:41 PM
RICHRAD's Avatar
z28redline
I'm gettin ready to order one made for my Q-jet .. Edelbrock part # 350-7104
Old Feb 10, 2003 | 09:35 PM
Rob116's Avatar
Engine: 355
Well, let's see, given my post, I could have just been pointing out that, with the search function enabled, he wouldn't have had to ask. Of course, I wasn't. My mistake. However, the fact is that I found three different topics in which he could have found his answer in the first five pages of the board.
Shooting off questions before you look is generally considered bad forum etiquette. I know that this isn't the most formal forum, however, I would imagine that at least a part of the difficulties with the search engine is the amount of useless posts that are thrown on here every day. Furthermore, if there weren't so many useless points, those topics that he could have used would still be on the front page, rather than being repeated again and again.
Sorry if you took my tone to be overly aggressive... Despite my mistaken correction, I wasn't rude and I gave him the response that he needed. Sure doesn't seem TOO terribly bad to me. Whatever. "You got me" My apologies to Z28 Redline.
Old Feb 10, 2003 | 09:46 PM
No4NJunk's Avatar
Sorry if you took my tone to be overly aggressive... sure doesn't seem too bad to me. Whatever. "You got me"
Maybe so. Its still not your job to tell people they need to search. We have plenty of moderators who can do that for you if they feel its a big problem. You've got 90 something posts so I really doubt you understand our board etiquette (not that it even matters anyway). I'm not sure what 3 topics you speak of. I haven't seen a topic on spreadbore manifolds in a while. I didn't "get you". Not sure why you think this is a game.
Old Feb 10, 2003 | 11:15 PM
Rob116's Avatar
Engine: 355
RIIIIGGGHHTTT
"Its still not your job to tell people they need to search."
Why not? I made a mistake this time and apologized, but if I can use the search feature, not bog down board resources, and keep valuable threads on the front page, why can't everyone else?
"You've got 90 something posts so I really doubt you understand our board etiquette"
Actually, I'd say that my low post count is a good indication of my understanding of "board etiquette". One, I clearly know how to use the search function - I'm on this board, finding information every day and I have less than a hundred posts. I've seen people that have been here for less time than me with over 400... What's better? Depends on the poster, I guess.
"I'm not sure what 3 topics you speak of. I haven't seen a topic on spreadbore manifolds in a while."
There's one post that mentions spreadbore manifolds and three that mention fitting a Performer RPM under a stock hood.
"I didn't "get you". Not sure why you think this is a game."
"Guess If you could read then you would have known this."
That's not a flame?
Once again, I was conservative in my criticism and now I've apologized.
Edit: Just wanted to point out that when I started using boards, I was criticized for not using the search function. I wasn't offended, as it was mentioned in the proper manner... In the long run, I have not doubt that the person who corrected me the first time (it wasn't a moderator, and it definitely wasn't here), was absolutely correct.
Old Feb 10, 2003 | 11:32 PM
No4NJunk's Avatar
Well if you feel there is a problem then contact one of the moderators and explain what you feel. Going around and telling others what to do is going to A) **** others off B) make yourself look like an ***. I'm telling you this from experience. Don't say I didn't warn you when people start REALLY flaming you. If you think I was blunt then just wait.
Uh....ok. If thats how you see it then great. Keep up the searching :sillylol:
That's not a flame?
Very much so. Why you ask?? because I've been here long enough to see many upon many post the same lame line......."search"!! I along with many others are sick of seeing it.
So that makes it right?? Well everyone knows to use the search but some circumstances require posting new threads. There are 20,000 some odd members on here. You can't get everyone of them to search, its just not possible. I personally search all the time and rarely ever post a new thread in here unless its something I can't find on the net or in search.
I'm done. This has already gone too far and taken too much "space" up. Sorry Z28, hope you got your question answered.
z28redline's Avatar
Engine: 305 lG4
Whatever... I would have done a search if it was up but it wasn't. I looked through the first couple pages of the board and I couldn't find anything that answered exactly what I wanted to know. I seem to get told to search almost every time I post, even when I research the topic first. No worries though, next time I will go somewhere else to ask a question. Sorry for clogging up your board.
z28redline
Old Feb 11, 2003 | 01:08 AM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
NO4NJUNK, just STFU already. I mean, you did ruin the entire post. Lay off.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
kyle5647
Aug 15, 2015 11:56 PM
TreDeClaw
Aug 14, 2015 06:58 PM
