hep solve an argument
Old Feb 15, 2003 | 10:04 PM
jmon92conv's Avatar
my dad and I are debating this. Does it hurt an alum. intake to lay flat on a shelf? He says I need to hang it so it will not warp. Any truth to this?
Jeremy
Old Feb 15, 2003 | 10:11 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
It will be fine.
Old Feb 15, 2003 | 10:29 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
There is no way it will warp!!
Old Feb 16, 2003 | 06:55 AM
ede's Avatar
ede
cranks are the only thing i ever heard of that needs to be placed a certin way to prevent warpage. of course we all know that glass over time will flow, or sag.
Old Feb 16, 2003 | 02:03 PM
Enkil's Avatar
Yes, but a very viscuous liquid isn't quite the same thing as a solid. heh.
Old Feb 16, 2003 | 02:41 PM
Vader's Avatar
Personally, I like to keep my crank standing straight up.
Take that for what it's worth.
Old Feb 16, 2003 | 03:42 PM
ede's Avatar
ede
vader i wouldn't touch that with a 10 foot pole, so to speak.
Old Feb 16, 2003 | 03:44 PM
llvll4l2c91350's Avatar
Hey I thought this was supposed to be only car talk!
Old Feb 16, 2003 | 04:22 PM
jmon92conv's Avatar
thats what I thought, and I always store my cranks straight up
Old Feb 17, 2003 | 12:48 AM
laiky's Avatar
Metal does not warp, only wood does, Thats why some people store their cranks standing strait up!!
Old Feb 17, 2003 | 01:25 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
wait are you guys serious? my eagle crank is standing straight up...
but the one in my car is NOT (duh) you cant be serious about cranks standing straight up in storage it makes no sense...
... or does it?
Old Feb 17, 2003 | 03:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's a myth, actually, although it's true about solid pitch.
Old Feb 17, 2003 | 04:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Glass flows even over a period of time as short as a few decades... the glass in the old medieval cathedral stained glass windows has had to be replaced several times over its life so far..... glass is actually a liqid by all scientific definitions, just a very thick one.
Aluminum however is not a liquid. I've never heard that about intakes. Somebody better tell all the intake mfrs to quit shipping them that way and storing them on shelves and so forth.
I had a cute little gewgaw hanging around for years, a great conversation piece; it was the thing for shiping a plumbicon tube, the image tube for some old TV cameras (the successor to the image orthicon tube), which had real fragile internal parts that could get bent if it got dinged the wrong way, so they had to be shipped in the upright position, no matter what. It was a frame you could nail inside a wooden crate, with a frame inside that on pivots so it could rotate, and a frame inside that one also on pivots, and the little tube that the plumbicon itself lived in had a lead weight in the bottom; it didn't matter what position the outer frame was held in, the tube always stayed upright. Maybe they should ship intakes in those.
Old Feb 17, 2003 | 05:05 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Actually glass is an amorphous solid, not a liquid.
Old Feb 17, 2003 | 07:05 PM
Enkil's Avatar
... or does it?
If a crank's sitting on a table, it's probably only supported by two points, a counterweight for example.
In your engine, I would guess (I would hope) that it's supported more evenly by more than just two points.
Old Feb 21, 2003 | 05:44 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b> (I would hope) </b>
your hopes are justified. the crank sits on top of the windage tray, rides on the main studs. thats where it goes, right?
Old Feb 21, 2003 | 06:16 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
Not mine, its right behind the canooter valve.
Old Feb 21, 2003 | 06:37 PM
flyway190's Avatar
Let's just call it a fluid and leave it at that.
Old Feb 22, 2003 | 09:41 AM
Changa2's Avatar
Don't give up so easily. Check this out.
http://www.wikipedia.org/wiki/Amorphous
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
Giocio
Oct 1, 2015 12:20 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
db057
Sep 4, 2015 07:57 AM
