Idling with a/c on
Old Feb 18, 2003 | 10:20 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Idling with a/c on
I am having some trouble with my a/c. It works fine at speed and blows nice and cold. However, when I sit at idle the rpm's surge. If I turn the a/c off, the idle rpm's are fine.
Anybody have a similar problem? Is there and air conditioning idle control?
Thanks.
Bill
Old Feb 18, 2003 | 10:22 PM
azvolfan's Avatar
I guess I should say that the problem is on my '87 Trans Am with a 305 TPI with 61,000 miles.
That might help.
Old Feb 21, 2003 | 07:59 PM
azvolfan's Avatar
anybody have any guesses???
Old Jun 13, 2003 | 05:26 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I got this problem too?????
Ever find out what it was???
Old Jun 13, 2003 | 05:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
is the compressor cycling on and off? That will cause an rpm surge because of the load/no load on the belt line when the compressor starts and stops.
Old Jun 13, 2003 | 05:58 PM
mypontiac's Avatar
Car: 1991 Conv. TA
No. Actually my surge only occurs when driving my 5 speed and going to neutral.
At a fixed idle it is OK.
I am suspecting dirty IAC.
Old Jun 14, 2003 | 08:26 PM
azvolfan's Avatar
WOW! This was an old thread that got reopened.
A full tune up smoothed out the rough idle and surging a little bit but it still does it. Still don't know why. Compressor is not noisy and the air is ice cold. In fact it is so cold that while driving to work the other day at about 1:00pm I had to turn the air down. It was about 107* outside at the time.
Old Jun 14, 2003 | 08:39 PM
mypontiac's Avatar
Car: 1991 Conv. TA
OK Hopefully I have your solution. Fixed mine!!!
I just needed to spray carb cleaner into the TB and IAC hole.
Did it while running and reving the engine and also not running to make sure liquid running out of TB was clear. Have paper towels handy.
Took her out for a drive w/ AC on and no more surging.
Very smooth idle.
Thank goodness!!!!
Hope this helps.
Old Jun 14, 2003 | 09:03 PM
azvolfan's Avatar
I will give it a try thanks!!!
Old Jun 14, 2003 | 09:07 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Let me know how it goes.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
IROCtometal
Sep 2, 2015 02:01 PM
