special tools?
Old Feb 22, 2003 | 02:33 PM
Raiden's Avatar
special tools?
What speical tools will i need to change out my timing chain?
Old Feb 22, 2003 | 03:15 PM
rezinn's Avatar
Balancer puller/installer. Torque wrench is nice as well.
Old Feb 22, 2003 | 05:09 PM
ede's Avatar
ede
i think the real question here is "timing chain on what?"
Old Feb 22, 2003 | 08:29 PM
Raiden's Avatar
l98 5.7 91z28
Old Feb 22, 2003 | 09:17 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
a hoist or jack would be nice... your going to need to lift the engine up a few inches to drop the oil pan to get the timing chain cover back on with out hacking it to pieces.
Old Feb 22, 2003 | 09:37 PM
Vader's Avatar
  1. Oil drain pan;
  2. Straightedge;
  3. OPTIONAL - Degree wheel, piston stop, and dial indicator(for degreeing cam if you desire - you might want to go +4° or so);
  4. Crankshaft snout socket (possibly);
  5. Seal remover/driver;
  6. Sharp gasket scraper;
  7. Wire cup wheel and die grinder/drill to polish gasket surfaces;
  8. Aforementioned balancer puller and installer;
  9. Grease for the TC front seal;
  10. White paint to mark the timing indicator on the balancer hub;
  11. Sensor-safe RTV for oil pan front lip seal;
  12. Anti seize compound for assembly;
  13. Bolt sealant for water pump installation;
  14. Medication for sore back muscles.
Aside from common hand tools and supplies (like oil and antifreeze) that should just about cover it. If you get a "three-way" timing set, one of the selections is normally +4°, as well as 0° and -4°. A lower-revving engine like a stock L98 can benefit from a little cam advance.
Old Feb 22, 2003 | 09:54 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i've dropped my oil pan twice in order to remove the timing cover. both time i didnt have to raise the engine...
Old Feb 26, 2003 | 05:01 AM
Raiden's Avatar
Originally posted by Vader
  1. Oil drain pan;
  2. Straightedge;
Yea, Med's for sore back muscles!!!
I feel like a fool! I was confused about the whole thing because I was looking at my old l98 engine buld up from my vette??? It had a l98 and i got the paper work mixed up. I thought the cam in my Z was a little off. turns out, I was looking at teh cam card for my vett instead of the cam card for my Z
92projectcamaro
Dec 8, 2015 12:25 AM
Thaney9
Oct 24, 2015 07:26 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Bradsaundry
Oct 7, 2015 04:35 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
