Where can I get an EGR Valve fairly cheap?
Old Feb 25, 2003 | 06:37 PM
91CustomRS's Avatar
Hello,
I am looking for an EGR Valve for a 1991 Camaro RS V6. I went to autozone, and discount auto. Autozone told me 163.99 for the EGR Valve, and Discount Auto told me $170 for the EGR Valve and Gasket. I am wondering, where could I find one cheaper than this (new naturally).
Thank you
Brian
Old Feb 25, 2003 | 06:48 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
You can try Kragen, and thats about it. After that, its only going to get MORE expensive, like say if you go to the dealer. You have one of those electronic EGR valves, which are not cheap. Have you tried to fix the one you already have? If anything, try to pick one up at your local boneyard.
Old Feb 25, 2003 | 06:52 PM
91CustomRS's Avatar
Hi,
I went to Kragon, and it is $170 ( a little more than autozone)....
Brian
Old Feb 25, 2003 | 08:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you get the real GM part #, you could try http://www.gmpartsdirect.com . I'm so glad I have a vacuum-operated EGR.
There's gotta be a way to convert a digital EGR into a vacuum-op'd EGR, isn't there?
Old Feb 26, 2003 | 08:24 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Yeah. Get the old mechanical block-off plate and reprogram your PROM.
Old Feb 26, 2003 | 11:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL... no, I mean actually rewiring the car to take the vac-op'd EGR system... the switch, solenoid, & valve. Oh... wait... doesn't the digital EGR open up incrementally? Hm, never mind.
Old Feb 26, 2003 | 12:47 PM
Vader's Avatar
From TomP
Yes, the digital EGR is basically a stepper motor, just like the IAC motor. There are two driver coils that are phased in different directions (½ phase apart) to drive the pintle either open or shut. These are driven by power transistors in the ECM, just like the IAC.
Presumably, you could install a stepper motor vacuum valve to accomplish the same thing. By the time you're done, you'd have the same functionality for probably a greater cost.
If it makes you feel any better, many/most cars now have direct-drive digital EGRs, so we're all hopping into the same boat. Your's just happend to be one of the first ones in the water. (Other cars had them as early as 1987).
Later,
Vader
WooHOO! We're in double-digits - ABOVE zero! Break out the sandals and shorts!
Old Feb 26, 2003 | 09:59 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
damn, if i would have known i wouldn't have used my egr valve for target practice via an AK47
1992rs/ss
Jan 31, 2025 05:10 PM
Out-Cast
Sep 3, 2015 09:05 PM
injdinjn
Aug 28, 2015 12:51 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Out-Cast
Aug 17, 2015 10:57 AM
