Can I use different bell-housing bolt holes?
Old Feb 27, 2003 | 06:18 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
If I recall correctly, there are a total of 8 bell-housing bolt holes that can be used to mount the transmission on a SBC engine with a 700-R4 transmission, and (at least on my car) only 6 of them were used. In my case, that meant the top two holes, the two holes below those, and then the very bottom two holes.
I'm wondering if, however, instead of using the two holes below the top two, I could use the two holes above the bottom two. The only thing that I can see that would be different is the bolt-length for those holes (the bolts that I'm using are bottoming-out). The ones above those are nearly impossible for me to see, let alone put bolts in and torque. I can't even remember how I got them out in the first place.
I don't see why there would be any problem with this--I just want to make sure that I'm okay to do this.
Then again... I might be mistaken about the extra bolt holes.
BTW -- Do I need to use thread locker on the transmission bolts?
Old Feb 27, 2003 | 09:24 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You won't need thread locker.
I think the other two holes have a locating dowel in them, so you won't be able to use'em.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
