Just Got New Rear End.
Old Mar 4, 2003 | 06:27 PM
steviey_bc's Avatar
and i was wondering if there was any way to tell what kind of gear ratio would be in this rearend? the guy said it was from a 5 spd T5 305 89 iroc. any help is much appreciated
Old Mar 4, 2003 | 06:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take off the cover and look.
The first thing you should always do with a rear end you just got is change the fluid. While you're doing that, make a point of looking at the gears.
Old Mar 4, 2003 | 07:02 PM
steviey_bc's Avatar
thanks for the tips
Old Mar 4, 2003 | 07:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Let us know... you might have just scored possibly the best rear end you can get for one of these cars, a 9-bolt 3.45 with PBR brakes. That would be cool.
Old Mar 4, 2003 | 07:30 PM
steviey_bc's Avatar
what are PBR brakes? ill get my teacher to look at it tomorrow. he'll probably know what it is :P ill tell u tomorrow. i paid 200 canadian for the used rear end.
Old Mar 4, 2003 | 08:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
PBR is the company that made them... they'll be aluminum calipers with cooling fins, not cast iron like the older rears (Saginaw calipers - yuck)
Count the cover bolts; 9 = 9-bolt, 10 = 10-bolt. Look at the gears; they may have the tooth count stamped in the edge of the ring (most do), it might say something like 12:41 which would be 3.42; or 11:36 which would be 3.27, etc.
Old Mar 5, 2003 | 12:44 PM
steviey_bc's Avatar
the stamp on the edge of the ring gear is 13:40
Old Mar 5, 2003 | 01:02 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
That would be 3.07 ratio.
Old Mar 5, 2003 | 01:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Almost...
Actually, it's 3.0769, or 3.08.
There's 2 3.08 combinations; that one, and 37:12, which is 3.0833.
Not a very desirable gear at all. And worst of all, a 2-series carrier. Still, for $200 Canadian (what is that, about $3.69 US?) it's not a bad deal, if it works.
Is it a 9-bolt, or a 10-bolt? Disc or drum? If disc, aluminum calipers or iron?
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
