Recommended Tire Size
Old Mar 4, 2003 | 06:53 PM
91_350TPI's Avatar
Car: Lucky Dog Racing 1992 Chevrolet Camaro Z-28
Engine: 379 cid Chevrolet race engine
Transmission: Coam TH-350 w/ transbrake
I'm putting a new set of tires on the GtA before spring and was wondering what tire size you guys recommend. I'm debating between 245 50R/16 and 245 60R/16. Any comments would be appreciated. Also what do you guys comsider the best tire out there for your buck$$. Thanks in advance guys. drive on.........
Old Mar 4, 2003 | 07:07 PM
91Z28-350's Avatar
Aren't 245/50-16 stock? If you go 60 series you'd have to make changes for an accurate speedometer and odometer.
Old Mar 4, 2003 | 07:11 PM
91_350TPI's Avatar
I realize this bit the 60 series is what was on the car when I bought it. However I don't know if the appropriate changes were made. Also, how would going with the 60 series over the 50 series affect the performance of the car? I like the taller tire just for the extra ground clearance. any more comments, suggestions? Drive on........
Old Mar 4, 2003 | 07:13 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Put on the 245/50R16s. They are the correct size.
The 60 series tires will most likely rub at full steering lock,, you will hate this in the future if the tire rubs.
Old Mar 4, 2003 | 07:58 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
you could go with 255/50/16 in back to get more rubber on the ground.....with 245/50/16 in front so you dont rub.....just my.02cents or 235/55/16 all around that will give you some of that clearence you were askin for and it will be lower than what u have
Old Mar 4, 2003 | 08:10 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
The previous owner probably put the 60 series tyres on it to save money. Most 50 series tyres are considered "performance" oriented. AKA more expensive. I would run the 245/50-16s all around.
A good tyre for the money is a BFG Comp T/A. I had Bridgestone Potenza RE-730 Z-rated rubber in the same size before I upsized to 17s. THey had great wet and dry traction and I abused them for about 8000 miles and they still had lots left in them. Just my opinion. Good luck.
Old Mar 4, 2003 | 08:15 PM
91_350TPI's Avatar
Is there any problem with the 245's rubbing up front? I thought about going with the 225's up there and 245's in the rear. keep the suggestions coming!! Drive on.............
Old Mar 4, 2003 | 09:11 PM
91_350TPI's Avatar
bump. Drive on............
Old Mar 4, 2003 | 10:18 PM
MikeS's Avatar
Even with the stock 245/50s, you'll probably see some rubbing on the inner fenderwell up front. This is not something that has been a problem for me though. I never feel it or hear it, but can see where they rub. I also like to keep the same size all around.
Old Mar 4, 2003 | 11:14 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
if u want to keep the same hight for all the tires u could just use the 10 / 5 rule for every ten u go up in width u go down 5 in hight that way u could have super wide tires in the back and not so wide tires up front and not have to worry about ride hight alittle trick i picked up from being a tire monkey
Old Mar 6, 2003 | 01:28 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i would say go for the 50 series tire as that's what belongs on it. if your going for ground clearance, you bought the wrong car.
Old Mar 6, 2003 | 02:22 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
You can fit 295/50-15s in the back..
Go with the 245/50s all around.
Old Mar 6, 2003 | 03:59 AM
90 GTA Black's Avatar
I just put on 255/50-16 on all 4. The fronts rub slightly when reversing and turning the wheel to the right. No problems with the rear. I would go with 245/50-16 on the fronts next time. Skip the 60 series - the better handling will compensate for any decrease in ride hieght.
Old Mar 6, 2003 | 06:56 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Whats with the whole "ride height" thing? After all it is a camaro or firebird, you know a sports car!! I think the 50s are required!!
Old Mar 6, 2003 | 09:05 AM
91_350TPI's Avatar
Thanks for all the comments guys. The only reason I talked about ride height is because I can't keep mud flaps on the car now with the 60 series tire on the car. It'll get even worse woth the 50's, but I guess the car looks better without them anyways . I think I'm gonna go with the BFGoodrich g-Force T/A KDWS. Their $114.95 per tire. According to tire rack.com the Bridgestone Potenza 950 is the best tire in class and their only an extra $8.00 per tire. Thing is that I need t spend $1,000.00 with Summit so I can be entered into the Super Series and hopefully win some big bucks with my dragster. Summit doesn't carry Bridgestone, so I'l compromise. Thanks again guys. Drive on.............
Old Mar 6, 2003 | 09:23 PM
MikeS's Avatar
91_350TPI,
I don't understand the comment about the mud flaps. They won't fit, or you just don't want them on there?
SuperTrans,
Can you explain that tip a little more? I'm not getting it to work out right using my math.
MikeS
Old Mar 6, 2003 | 10:18 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I have 245/50-16 Dunlop 5000's on my '92 Camaro and 255/50-16 on my '87 Trans Am. The Trans Am has Kuhmo's in the back and Falkens in the front. Very slight rubbing in the front on the Trans Am. Not a problem though. Out of the 3 tires I think I like the Falkens the best. I have had them in the past and had good luck with them. If money were no object, I would go with the Bridgestone S03 Pole Positions. But I am not sure they even make them in a 16 inch rim.
Old Mar 7, 2003 | 12:01 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
id stick with the 245 50 16s, they seem to look the best on the third gen wheels and ur not gonna get much more of a tire patch with a 255 50 16s
Old Mar 7, 2003 | 07:36 AM
Slade1's Avatar
I'm quite partial to my 245/50/16 size tires...
I've had no issues with rubbing on the front at all considering these are stock size for the car
Old Mar 7, 2003 | 07:51 AM
91_350TPI's Avatar
Mike S: It's not that I don't want the mud flaps. However every time I pull into my drive way one of them gets ripped off the car. Like I said though, the car looks beter without them anyways. Drive on............
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
toronto formula
Nov 10, 2015 06:17 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
knight72
Aug 10, 2015 09:32 PM
