Do I have to remove the hood to pull distributor?
Old Mar 10, 2003 | 01:00 AM
firestorm's Avatar
Car: Firebird
Engine: LG4
Do I have to remove the hood to pull distributor? Or is the dist not that long?
Thanx
Old Mar 10, 2003 | 01:04 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Not that long.
Old Mar 10, 2003 | 01:29 AM
firestorm's Avatar
Car: Firebird
Engine: LG4
Thanx man. I sure didnt want to have to pull the hood off
Old Mar 10, 2003 | 02:03 AM
377ciTT's Avatar
Car: 94z28,84 3rdgen no engine,64 vette
Engine: lt1,-,350
Transmission: t56,-,m4
Heh if your my buddie you can do it in the dark with no light heh in under 10 mins but just remeber to mark the dist in 2 places or 3
Old Mar 10, 2003 | 06:04 AM
ronterry's Avatar
Car: '94 Corvette
Maybe this will help scale it for you.
Good luck on your project.
Ron
Attached Thumbnails Do I have to remove the hood to pull distributor?-mvc-547x.jpg
Old Mar 10, 2003 | 04:13 PM
89WS-6's Avatar
I didnt have to pull mine.
Old Mar 10, 2003 | 08:57 PM
zr1 32 16 405's Avatar
definetly not, just unbolt a little screw ( i made my own to do it) and MARK IT as i have learned the hard way and just pull it out.
Old Mar 10, 2003 | 09:46 PM
KC10Chief's Avatar
That bolt is 14mm if I remember correctly. A 14mm crows foot wrench works great for this! You can get a craftsman one for a couple bucks. Anyways, mark the distributors position with the intake. Use a sharpie and mark the distributor and intake so yo can line it back up! Also, make another mark on the rotor and one on the distributor to line up the rotor when you put it back in! Unless you rotate the engine with the distributor out, it should go back in without having to time it. Even if you do rotate the engine, you can get the #1 piston to TDC and line up the rotor with the #1 spark plug tower on your distributor cap and then line up your mark on the intake! Matt
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
