xe274 and Vortec Heads
Old Mar 10, 2003 | 12:53 AM
AMilk's Avatar
You Guys think they would work well together on a 400 SBC? I want a slightly lopey idle, 400+ HP, and 450+ torque. Thanks in advance!
Old Mar 10, 2003 | 02:09 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Not without machine work and new springs.
Old Mar 10, 2003 | 02:37 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes that would make a good street machine package.
Would need a bit o' gear and converter but other than that
easy to live with and lots o' power.
Be sure to do the proper upgrades to the valvetrain to get the best out of the Comp XE cam.
If you have any questions, Comp Cams has a free tech line.
Give them a call or e-mail.
Old Mar 10, 2003 | 05:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes that combo would run great.
It will also require machining the heads for larger springs, and cutting the valve guides down so that the retainers don't hit them.
Given that, it should work fine.
Do not even begin to hallucinate that you can use the weenie truck replacement valve springs that come on those heads with that cam. Those heads do not come set up as a performance head from the factory, they are a replacement trcukc service part, and as such, require complete prep from ground zero to be used with a cam that big.
Old Mar 10, 2003 | 10:31 AM
AMilk's Avatar
Thanks guys! ya, I know about the vortec heads... Im buying the beefed up ones. How about vacuum... will I have enough?? (PB, future A/C)
Old Mar 10, 2003 | 11:21 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Friend of mine combo (commonly known as Pony Killer)
71 4 bolt main truck block 30 over, decked negative,alignbored,
4130 forged crank, X rods, Trw flattops, ballanced, .039-.040 head gasket(I forget) Pistons have a positive deck height
Heads GM vortecs, shaved a tad, Valve job, bowl work, stock valves "Z28 springs) a shade over 61 cc. Static compression 10.65-10.75 Comp XE 274 cam. crane race gold 1.5 rollers.
Edelbrock performer rpm intake, 780cfm 4150 holley.
HEI with a petronix flame thrower rebuild kit.
SLP 1 3/4 non air headers, to a dump, then into a one out flowmaster, in the stock location. Trans. 700r new gearsets, sprags, reaction carrier, and a brand new front pump. ATI "custom" converter 9.5" 3300 stall lockup joint. the dreaded ten bolt with 3.73 gears. bob's ole mickey T's on 10 dollah rims(can you see where the money ran out )
subframe connectors by spohn, his adjustable torque arm, boxed lca's and panhard rod. old *** front struts, and 3 way adjustable summit rear shocks. ugly riveted on 4" cowl the air cleaner sits up over 2" inside of it...
Just ran a 12.5@109 mph at Atco this past saturday. PK still has some tuning todo and get the 60' down lower than the 1.9s.
Kat
Old Mar 10, 2003 | 11:28 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
That cam will be good. Actually it won't lope I bet. Does slightly on my 383 but not much.
Old Mar 10, 2003 | 07:54 PM
BillZ28's Avatar
Car: 84 Z28
Car Craft put together a 440 horsepower package with the Vortec Heads, XE 274, and a 350 small block.
Old Mar 10, 2003 | 09:10 PM
AMilk's Avatar
Thanks for the replys guys.
Aaron91RS - do you think I could get away with the xe 284? 400's make alot of torque and id be willing to give up alittle for somemore HP. Ehhh... I'd probably be happier w/ the 274 streetwise... I just want that killer idle!! Id hate to rev it up real high though...
BillZ28 - you have to tell me what issue that was!
The car the engine is going into will have a 4-speed and 3.42 gears.
Old Mar 10, 2003 | 09:52 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I summarized the Hotrod Vortec headed 383 buildup in this thread. Check it out: https://www.thirdgen.org/techbb2/sho...&highlight=383
They ran the XE282 hydraulic roller and got 463hp and 500 ft-lbs with a 383 with the Vortecs after some tweaking.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
