damn the 305
Old Mar 12, 2003 | 07:15 PM
TallWhiteGuy's Avatar
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
damn the 305
Okay i have had my car for a good 6 months, and i have noticed that when in 1st gear (5 speed) or reverse it will have somewhat of a knock. Now my mom was in the car and she said that it is bad gas, i haven't put higher octane it so i was wondering if she is right or is there something horribly wrong with my engine?
Old Mar 12, 2003 | 08:13 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
as a general rule of thumb, consider everything a woman says to be wrong............:rockon:
Old Mar 12, 2003 | 08:31 PM
305LG4Cutlass's Avatar
My friends Beretta 5spd does something like that. If it only does it in 1st and reverse and has nothing to do with engine speed or engine load then my guess would be its something in the transmission.
If it was making a little knocking sound only under partial load and went away while idling or full throttle i'd suspect its pinging and putting in higher octane would help.
Old Mar 13, 2003 | 12:22 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Retard your timing a degree or two. Should fix it without getting ROBBED for premium fuel
Old Mar 13, 2003 | 11:11 AM
Engine: 305 tbi
Transmission: t-5
Yeah 350cutlass... it will only do it under a little bit of a load, thanks for the unput
Old Mar 13, 2003 | 11:31 AM
Vader's Avatar
TWG in Texas,
What engine/fuel system is this? (It always helps to know.)
It could be inadequate octane, could be carbon buildup, overheated combustion chambers, lean mixture, lots of possibilities.
If it's ae early-mid '70s Olds, the valve rotators tend to make a slight "rattle" sound anyway, but it is distinctly different than a detonation sound.
Old Mar 13, 2003 | 12:52 PM
Engine: 305 tbi
Transmission: t-5
it's a 305 tbi if that helps with 116k on it and it 's a 90 rs
Old Mar 15, 2003 | 04:30 PM
TBIfly's Avatar
a knock, huh...? just one or several ?
MY only 2 bits is this,
crawl beneath the car, as its on stands and take the E brake off and take it out of gear
grab the driveshaft and rotate it back and forth, check for backlash
If it moves considerably you may have a problem. maybe bad U joints, gears going out. but i dont know too much about drivetrain.
GouldyGTR
Sep 7, 2015 09:05 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
TBRays98
Sep 6, 2015 05:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
