lovely popping
Old Mar 13, 2003 | 06:48 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
lovely popping
ok my car is popping...one guy said it may be way to rich and another said one tooth off on distributer....what do you think?
Old Mar 13, 2003 | 07:05 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Could be that "Crappy rigged up Y-pipe". If the pipe is leaking than a popping noise will result. Check for exhaust leaks.
Old Mar 13, 2003 | 07:25 PM
Car: 83 Camaro
Transmission: th350
well it goes away once i give it some gas so its not the y-yipe....my pipe is just welded together with all angles from straight pieces.....no bends...hehehe......what if i moved eash plug wire one over counter clockwise
Old Mar 14, 2003 | 05:54 AM
Car: 83 Camaro
Transmission: th350
ttt
Old Mar 14, 2003 | 01:52 PM
Car: 83 Camaro
Transmission: th350
ok i moved the distributer 1 notch.......still crappy.....moved anbother....moved another....finally just got out thie timing gun and and lined it up and stuff so the timing is perect.....ok so i start it up....the *** damn poppig is still there....the carb sure as hell aint likin it....but it seems to be working fine.....the popping is repetative and fairly steady at idle.....once a second or two......im getting pissed....it aint exhaust cuz you can hear it out the back exhaust...very high pitch and mettalicy back there...up front more thumpy......what is it.....it will hold a steady idle if it dont back fire....you give it gas and it is somewhat better.....but when driving it and you give it gas it just dies.....do you think it could be my distributer?.....i really hope i didnt round off another cam
Old Mar 14, 2003 | 04:29 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Any moisture in the distributor cap? Bad plug wires?
Old Mar 14, 2003 | 04:36 PM
Car: 83 Camaro
Transmission: th350
i got old beldin wires on my car right now....my friend said he thought those had a lifetime warrenty at napa?
Old Mar 14, 2003 | 08:28 PM
bes217's Avatar
I would say an exhaust leak. Mine did that and when I fixed it the popping noise went away.
Old Mar 15, 2003 | 09:45 AM
Vader's Avatar
Benny,
Popping in the exhaust (afterfire) or the intake (backfire)?
Possibilities are:
  • Broken valve spring;
  • Incorrect valve/cam timing;
  • Sticking, bent, or damaged valve;
  • Excess carbon in a chamber;
  • Excessively lean mixture;
  • Vacuum leaks;
  • Exhaust leaks;
  • Ignition crossfire from bad cap or wires;
  • Worn distributor;
  • Weak ignition coil;
  • Failing spark plug;
  • Leaking EGR valve;
  • Plug gaps too wide;
  • Dirty carburetor passages;
  • Water in fuel;
  • Fuel filter clogged/pump failure.
That should give you a weekend's worth of things to do...
Old Mar 16, 2003 | 09:32 AM
Car: 83 Camaro
Transmission: th350
sweeeeeeeeet...thanks guys i managed to score new wires for free cuz of the warrenty and now she purrs like a kitten again
Old Mar 24, 2003 | 11:16 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
Hi Vader,
I am currently trying to tune a supercharger on my 1991 TPI TA.
I am getting popping from the exhaust.
I asked my prom programmer to make a leaner program as I thought this problem was from unburned fuel.
Is this right?
By the way I am also getting 11:1 to 12:1 wide band A/F ratios.
Thanks.
RS Reaper
Oct 17, 2018 07:52 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
Lmancha96
Sep 25, 2015 08:11 PM
