zz4
Old Mar 23, 2003 | 07:26 PM
carnut3's Avatar
zz4
What kind of quarter mile times would u see with the below mods just with the zz4 crate motor in it. I am saving up some money to buy one and just thought i would ask.
Old Mar 23, 2003 | 07:27 PM
carnut3's Avatar
mods
whoops forgot the mods...
3.73 posi
600cfm edelbrock
edelbrock performer intake
dual exhaust
headers
rear suspension work
Old Mar 23, 2003 | 07:38 PM
jimmy_mac's Avatar
Just a guess, in a 3rd-gen camaro I would say low 14s at 97 to 100 mph. With suspension and good tires maybe high 13s. That's just a guess.
Old Mar 23, 2003 | 10:08 PM
jdrafke's Avatar
Well i was looking to get in the low 13s with one. Is this possible jsut stock. and if not what good cams would go better and maybe bbost up the horse power a bit. Aos how would a stock zz4 in a third gen like mine fair up against an ls1 equiiped camaro/vette
Old Mar 24, 2003 | 05:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You won't get low13s out of a setup where the carb is too small by as much as that one is, and where you've downgraded the intake by taking off the ZZ4 one and putting on a basically stock one (Performer).
A properly set up ZZ4 as it comes, with a Holley 750, is good for about 345 HP, before accessories and stuff like that. I'd say your mods will trim about 25-30 HP off of that, and you'll lose another 20 or so from a water pump, alternator, air cleaner, etc. Since you're talking about "dual exhaust", your weight will go up but your power won't. In a typical one of these cars at 3500 lbs, that 300ish HP should put you at about 14.3-14.4, give or take a few.
The LS1 output has varied some over the years, but just for a nice ballpark average, let's call it 380 HP, after accessories and other chassis installation losses. You won't be in the same ballpark. You will get slaughtered. A stock ZZ4 would do somewhat better but still far short of a real contest.
Old Mar 24, 2003 | 08:38 AM
ctandc's Avatar
That's strange...
Mike Davis bolted in a bone stock ZZ4 into his TPI car, which everyone claims STRANGLES the ZZ4 on HP.... he didn't even add headers... just matched the ports on the exhaust manifolds to the D-ports on the ZZ4 heads. Hmmm...stock TPI too.....he ran mid 13's....
Traction and chassis setup and TUNE is the biggest variable. You can take 10 3rd gen's, install 10 ZZ4's, and you'll have 10 different ET's because of the differences in the cars setup, chassis wear / setup etc......
The 600cfm is a bit small...sell the Performer and use the ZZ4 intake....it's alot better.
With some traction and careful tuning, I see no reason why you wouldn't be able to break solidly into the 13's.
In fact, the GM Camaro mule, that was setup to swap in the ZZ4 and remain SMOG LEGAL, it ran 13.80's with exhaust manifolds, and the computer controlled Q-Jet.
HTH
Old Mar 24, 2003 | 02:49 PM
BillZ28's Avatar
Car: 84 Z28
The best time I've seen a ZZ4 go in a 3rd Gen in relatively stock form was 13.7. That was with a 750 CFM carb, 1 5/8" headers and 3" I pipe. So I'm assuming mid 13's are possible out of the ZZ4 with the right setup (suspension/exhausT).
Old Mar 24, 2003 | 04:00 PM
ctandc's Avatar
Hmmm.......check Mike Davis site
http://www.eecis.udel.edu/~davis/z28.../zz4_slip1.jpg
13.61 @ 99mph with a STOCK TPI and ported exhaust manifolds.....
TPI outrunning a carbed car? Egads......Imagine that......
Old Mar 24, 2003 | 04:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What was the car weight? What had he done for traction and maybe a converter?
There's more to track times than HP.
Old Mar 25, 2003 | 03:20 PM
jeff's Avatar
What would it take for a ZZ4 to run mid 12's on street tires. Didn't they sell an upgraded ZZ4 that had more horsepower at one time?
Old Mar 25, 2003 | 11:23 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
zz4 with them mods set up properly would be good for mid 13's. the zz4 only has had one hp rating.
Old Mar 28, 2003 | 04:02 PM
jeff's Avatar
anyone ever put one of these in a thirdgen? 1/4 mile times?
http://www.sdpc2000.com/cart.asp?act...=1578&pid=2598
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
