Check Engine Light with no code
Old Mar 24, 2003 | 12:25 PM
wtknt72's Avatar
Car: 1991 Trans am
Transmission: tremec tko600
I have a 91 Pontiac Trans Am. With a blueprinted and balanced tpi 350 with 6000 miles on it. L98 heads and tpi specialties l98 super profile cam. I had superchips burn a custom chip and i have delco computer. Brand new battery, brand new msd coil, 8.8 ignition wires and new bosch platiunum +2 plugs, new accel ignition moduale. It has a flowmaster 3"catback system and high flow cat.
The check engine light comes on after you are driving highway or a constant speed for a couple of minutes and doesnt go out untill you turn the car off. If you are driveing city or just around town there is no light and when the computer was put on it no code shows up. The Air mixture gauge look slike its running alittle rich. Any ideas?
Old Mar 24, 2003 | 02:16 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd suggest you have the person with the scan tool, monitor the ECM while driving. If the SES light coming on is repeatable, should be easy to nail down the bad parameter....then look towards repair
Old Mar 24, 2003 | 04:40 PM
wtknt72's Avatar
Car: 1991 Trans am
he said he did do it while he was driving and ses light was on and no code was being shown
Old Mar 24, 2003 | 09:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, what he needs to do is monitor the sensor inputs, and look for one that is going out of range....not just wait for a code to set.
Is he using an actual scan tool, or just a code scanner?
Old Mar 25, 2003 | 01:45 PM
wtknt72's Avatar
Car: 1991 Trans am
he is using a code scanner...whatever the full computer things is with the screen and everything not the thing that you get for 29$
Old Mar 25, 2003 | 07:54 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
try a tech 1, chances are the after market scanner is missing something. also double check your ecm connections
Old Mar 25, 2003 | 08:19 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
could this be happening cause the car is coming off open loop or into open loop whicheve one happens after being warmed up?
i dont kn ow just stabbing away
Old Mar 26, 2003 | 09:58 AM
wtknt72's Avatar
Car: 1991 Trans am
I thought it was an open loop situation also but if i drive local streets I can drive all day with no ses light. Only when I am at a constant speend for a few minutes.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
