I am having a problem ???
Old Apr 1, 2003 | 03:24 PM
jules91Z28's Avatar
Was hoping someone could help.My car 1991 Z28 305 TPI runs great ....Can drive all day untill it reaches 220 or so .Then if I turn it off it cranks right over and tries to run ..kinda coughs sputters you cant push the gas down nothing happens so I come back a few hours later .Starts right up??? runs great again any Idea on what this can be any help would be greatly apreciated.Thank you
Old Apr 1, 2003 | 04:52 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Is it throwing any codes? Check engine light coming on or anything?
Old Apr 1, 2003 | 05:25 PM
jules91Z28's Avatar
hi
nope no codes with the tech one... brought home from HITHERE chevy dealer ?? no check engine light nothing
Old Apr 1, 2003 | 05:31 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Could it be the injectors leaking? Anyone else have any ideas? It almost sounds like HITHERE sensor is getting hot and not working correctly. HITHERE don't know on this one. Sorry HITHERE can't help more.
Old Apr 1, 2003 | 05:52 PM
jules91Z28's Avatar
thanks
just had HITHERE new injector put in and all the rest serviced..... this sucks just spent 1200.00 for everything but this prob....thanks
Old Apr 1, 2003 | 07:01 PM
jules91Z28's Avatar
[HITHERE]Originally posted by 94-6spd [/HITHERE]
HITHERE wish HITHERE could read what the name of that sensor is ....darn hithere its funny but .........
Old Apr 2, 2003 | 10:01 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I just thought it could be a sensor getting hot and not working correctly.
Old Apr 3, 2003 | 09:15 AM
Vader's Avatar
You may also have an FPR that's leaking through the diaphragm and flooding the plenum. It's easy to check by removing and capping the vacuum hose while watching for fuel spillage out the regulator hose bibb.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
