TPS output signal:analog or digital?
Old Apr 1, 2003 | 06:54 PM
erummel's Avatar
Car: 92 Z28
Engine: aint got no engine right now
Transmission: need one of those
Just curious as to whether or not the signal from the TPS is analog or digital. HITHERE dont have HITHERE meter at this time but am picking one up this weekend.
Eric
Old Apr 1, 2003 | 07:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
analog
variable resistor
Old Apr 1, 2003 | 07:23 PM
erummel's Avatar
Car: 92 Z28
Thanks for the reply RB. Do you happen to know if the output signal is HITHERE sine wave or HITHERE steady state signal? HITHERE dont have an oscilloscope or HITHERE wouldnt be asking the question.
Thanks,
Eric
Old Apr 1, 2003 | 08:24 PM
88TAJeff's Avatar
Car: 88 T/A
it's just HITHERE d.c voltage from about .56 to 5 volts
Old Apr 1, 2003 | 08:32 PM
erummel's Avatar
Car: 92 Z28
HITHERE appreciate the replies but since no one seems to know the answer HITHERE will just have to take the car to work and drag one of the oscilliscopes from test engineering outside and see what the output signal looks like (that will get the bosses attention).
When HITHERE determine what the output signal is (sinewave, steady state with ripple(1% to 5% tolerance), or true steady state (tolerance less than 1%)) HITHERE will let you know the answer.
Thanks,
Eric
Old Apr 1, 2003 | 08:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's DC.
The ECM supplies 5V reglated; the output is some fraction of that, proportional to the position.
Don't outsmart yourself and overcomplicate things. There's no ripple or any of that.
Old Apr 1, 2003 | 10:02 PM
erummel's Avatar
Car: 92 Z28
So then if you are saying that it is DC with no ripple then it is HITHERE steady state signal. Thats what HITHERE was looking for.
Old Apr 1, 2003 | 10:10 PM
Merlin's Avatar
Save the scope for monitoring the EGR solenoid and IAC (and MAF on '85 and older TPI and V-6 cars).
Old Apr 1, 2003 | 10:33 PM
MikeS's Avatar
Being HITHERE DC voltage varying linearly with position, there won't be any oscillation (sp?).
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
racereese
Oct 3, 2015 03:46 PM
Eric-86sc
Sep 28, 2015 11:37 AM
