what is this..???
Old Apr 10, 2003 | 08:13 PM
DreamState21x's Avatar
what is this..???
ok, on the bottom driver side of the TB(on TPI) there is and "L" shaped black rubber piece that looks like it should have a hose connected to it or something.. What is this, and should anything be connected there? Thanks all...
Old Apr 10, 2003 | 09:16 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
that is a vacuum line that goes to the EGR solenoid over on the passenger side by the distributor. it splits and also goes to the fuel vapor canister over by the passenger fender.
Old Apr 10, 2003 | 11:01 PM
Vader's Avatar
Same as last time:
Old Apr 11, 2003 | 02:25 PM
ahhh ic
So that does connect to the eecs VIA the plastic line with the "T" fitting on it.. Someone told me a while back that it was not supposed to be connected to anything.. I figured that line went there but it wasn't long enough so I wasn't sure.. Whats problems if any would that be causing being unplugged...??? Thanks everyone i really appreciate it...
STIFFLER
Jan 1, 2003 06:18 PM
Skatepunk60
Dec 25, 2002 01:28 AM
definitive1
Aftermarket Product Review
Dec 20, 2002 10:34 PM
Hrock
Dec 17, 2002 11:49 PM
92fire-audio
Sep 5, 2001 12:10 AM
