i need air condition help ASAP!!
Old Apr 13, 2003 | 03:34 PM
CamaroEFI's Avatar
im in the middle of working on my car right now and im taking out the air conditioner condensor. my question is what is the line coming from the canister (where the freon is) going to the condensor ( the one w/ oil in it)? that line also has some kind of sensor connected to it if that helps any. i need to know what that line is because i don't know if i have to plug it or not. thanks
Old Apr 13, 2003 | 03:53 PM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
Need more info. Is the "canister" close to the firewall?
Old Apr 13, 2003 | 04:04 PM
CamaroEFI's Avatar
yes, i believe its the evaporator..its the silver canister on the pass. side
Old Apr 13, 2003 | 04:13 PM
Vader's Avatar
That "sensor" is a high pressure switch. If you cut it out and do nothing with the wiring, the electric cooling fan will operate continuously whenever the ignition is ON.
Old Apr 13, 2003 | 04:15 PM
CamaroEFI's Avatar
thanks for the help..i figured it out
Old Apr 13, 2003 | 04:17 PM
LnealZ28's Avatar
Car: 1987 Z28
The silver canister is the accumulator and the switch is the low pressure switch. The line leaving the accumulator will go to the compressor. Are you permanently ditching the A/C or are you just removing it temporarily? Does the system still have freon in it?
Old Apr 13, 2003 | 05:14 PM
CamaroEFI's Avatar
no, the system doesn't have freon in it. i want to take the ac compressor out cuz i don't need it but it doesn't look like i'll be able to till i get time to get another serp. belt. i already took the condessor out and the lines that were going to it i just left unplugged...that won't hurt anything will it?
Old Apr 13, 2003 | 05:53 PM
LnealZ28's Avatar
Car: 1987 Z28
The reason you want to plug the lines is to keep atmosphere (moisture,etc.) out. If you're not gonna be using the A/C anymore don't worry about it.
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
