Cam install.Gone wrong?
I install a comp cams 270h cam in my truck today.
I have the motor at TDC on the intake stroke.The dots on the timing gears are lines up.The thing is the 1st lifter on the driver side.Is up a little bit.Just a tiny bit.
Is something wrong.I thought that both lifter's should be all the way down.
Any thoughts?
Any thoughts?
Car: 85 Z28
Engine: LG4 modified
If one of the lifters is up when the timing marks are lined up, it normally means that #6 is at TDC, and you need to turn the crank one full revolution to get #1 to TDC.
I think.
I think.
Well that makes since.When I installed the cam both where down.Then I rotated to make sure everything was alright.And my mom started screaming at me for taking my truck apart again.(I have a tendancy to do that)So I quit paying attention.
Now I am waiting for my intake and carb.Hopefully those little 4 cylinders wont be a problem!
Car: '94 Corvette
Your fine, and installed the chain correctly. The instructions have you line it up dot to dot, cause it's easier.
Like 'si_camaro' said your crank & cam are at #6 TDC. Something the instruction fail to mension some times.
Techniclly both dots are at the 12 O'clock postion to be at #1 TDC.
BTW: I also install my chain dot to dot. It's easier & you don't need a straight edge.
Ron
Ron
Well that is good news.
I just looked up the casting # from the heads.They got 1.72 and 1.50 exhaust valves.Casting # 3927185.Well dangit.Are 882's any better than this.My cousin has some that I might be able to get ahold of.
I am still hoping for good results.Cam,intake,carb swap all at once.next on the list is headers.Then I guess heads.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
882's have huge 76cc chambers but bigger valves, while the 185's have 70cc chambers and tiny valves. Your call they are both crap.
