Whats My Rear-End Specs?!
Old Jul 24, 2000 | 01:40 PM
Slow88RS's Avatar
whats the specs on a 88 RS SC 5.0 TBI? 9-Bolt right? what kind of gears should i get and when i buy a gear (ex. 3.73) does it come with posi? thx, peace
K&N Air Filter 14x3' Open Element, Edelbrock Catback 3", TES Edelbrock Headers, 3" Dynomax Hi-Flow Cat, 8.8mm Accel Spark Plugs, Underdrive Pulleys, JET Chip (Thurs of this week)
My 88 RS
Old Jul 24, 2000 | 02:46 PM
R Defever's Avatar
I think 9 bolts were only used w/ the BW 5-speed. If it's an automatic it should be a 7.5" 10 bolt, right? Either way w/ that motor you should probably get the 3.73's. When you buy gears they only come w/ the ring and pinion if necissary. A locker would be a completely different purchase.
85 Z28 (Soon to be GMPP 350 HO)
Headman Hedders and matching y-pipe, Edelbrock Performer, Ram Air, Accell cap and rotor, Accell Supercoil, 160 stat, highflow Catco converter, absolutely no other smog equipment, B&M shift kit, Rapidfires, numerous carb mods, and flex-a-light fan.
"If you think education is expensive, try ignorance."-Ben Franklin
Old Jul 24, 2000 | 04:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You should have a 7.625" (7 5/8") 10-bolt right now, with 2-series 3.08 gears. When you buy new gears, you'll want ones for a 2-series carrier. Your best bet would be to try to find a whole new rear end with posi, because gears are just gears, you'll still have the open differential.
1991 Camaro Z28
5.7L 5-Speed
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Webmaster: ICON Motorsports
Old Jul 24, 2000 | 06:41 PM
Slow88RS's Avatar
yes but my stock gears are like 2.78 or something. the 89 irocs were just as bad. i thought u can buy posi and get rid of the open differential? thats what i would like to do. can you give me ur opinions and price thoughts? thx guyz
My 88 RS
Old Jul 24, 2000 | 06:45 PM
R Defever's Avatar
Yeah you can buy a "locker", it's a posi. Summit has them i think, and jegs might too. If they don't carry them you can easily find a company's web site that produces them.
Old Jul 24, 2000 | 08:11 PM
Kevin91Z's Avatar
If you get a posi, you'll need one for 26 spline axles.
Old Jul 24, 2000 | 08:17 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Better crawl under your car and count he bolts before ordering anything.
If you clean off the rust on the forward-right side of teh axle and find the three character alphanumeric code (quarter-inch high characters), we can look it up for you and tell for sure.
if you want to upgrade to a Torsen, you could always reference my page:
http://www.isthq.com/~dan/10bolt.html
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
Old Jul 24, 2000 | 08:19 PM
92TRANSAMWS6's Avatar
JEG's has a 26 spline auburn gear posi unit that will fit your car for $299.99.
92 Trans Am/WS6/305/5Speed/T-Tops/K&N filter/Flowmaster Muffler/Ported Plenum/more mods to come.
69 Camaro/427-currently undergoing restoration
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TexasMaro
Sep 15, 2015 06:50 PM
angel2794
Sep 8, 2015 06:22 PM
