Thanks!! Brakes now work!
Old Jul 25, 2000 | 08:44 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I tried what Engineboy suggested, and replaced both rubber brake lines up front. They were a serious PITA to replace, but well worth it! Front and rear brakes now work great. Of course, I also needed to replace the master cylinder also, because the piston inside jammed due to corrosion. First time I could at least gun the car in the driveway and feel confident that I wouldn't crash through the back of my garage!! The car seems to have plenty of power becase I can let out on the clutch, then gun it, and it will spin tires and kick the rear sideways!! Of course this could be a bad thing also from a 1/4 mile standpoint. I've read some posts about people putting ATF in there 5-speeds, and I'm running 80w-90 in mine because that's what my book said. So now I wonder if I put the wrong stuff in. Is gaer lube the correct lube for a '83 T-5?? It seems to operate smoothly. Thanks again for everyone's help!!
Freshly rebuilt 19831/2 or 3/4 Camaro Z28 305 H.O. 3:73 Gears, BW T-5, Duel Snorkle, Rhino Clutch, 2040 Compu-cam, LS1 valve springs, porting, PST front end kit, K&N Filter and runs great but ain't streetable yet!!....Future Mods: Not yet decided if I'll keep it!
Old Jul 25, 2000 | 09:22 AM
Lounge Lizard 6's Avatar
You say the book called for 80w90? ATF is the only factory recommended lube for a T-5 that I've heard of. I run Red Line MTL in mine because ATF is just a little too thin. Don't know what the long term effects of 80w90 would be.
Mike
'90 IROC, 5-speed, ZZ4, & Trick Flows
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
stalkier
Aug 13, 2015 12:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
