why can't it go below 220
Old Apr 22, 2003 | 03:34 PM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
My car runs at 220 degrees with both fans on, I'm running a 180 thermostat, 176 degree fan switch at is still runs 220. I also have a manual fan switch for the second fan. I already took out the a/c condensor, new 15lbs radiator pressure cap, running a 50/50 coolant water mixture, and the air dam is still in good condition. Why can't it go below 220. If I change the coolant to water mixture to 30/70 will it help to cool the temp down. Also I noticed that my top radiator hose is puffed up (expanded from normal position) is this normal? And when racing down the 1/4 the temp seems to rise about 10 degrees. What can I do to drop my temp?
1988 Iroc-Z 5.7 tpi
Hooker Super Comps (Shorties)
AFPR, K&N, MSD 6AL, Ram air
Best time 14.09@97mph.
Old Apr 22, 2003 | 06:17 PM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
number of things i guess, some people say egr valve could be sticking, other people would say that your timing is off, and others would say its just the climate you live in or even a mixture of all three.
Old Apr 22, 2003 | 06:57 PM
racing_dude_17's Avatar
is the sending unit electrical if so have you changed either the sending unit or the temp guage. my dad had that problem when he swapped guages in his blazer, it ran way hot(210-220) then he got a manual guage and it read 180-190
Old Apr 22, 2003 | 08:07 PM
Car: 1988 Iroc-Z
Engine: 5.7 TPI
What effect would changing to 30/70, antifreeze/water mixture be on my temp. Will it run hotter or colder?
Old Apr 22, 2003 | 08:25 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
should just increase the cooling capacity, so it might run a little cooler
yeah your gauge might not be all that accurate
Old Apr 22, 2003 | 10:48 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I have the setup you have with a single fan and my guage never goes past the 160 mark on the stock POS gauge. That could be off tho. I figure its alittle warmer than that. Actually i have a 195 in there now for winter...and it still stays that cool. I dont know whats up unless your water pump is starting to fail possibly?
Old Apr 22, 2003 | 11:09 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Have you considered the possibility of a stuck thermostat? Or a completely crudded out radiator? Or a worn out water pump impeller?
Old Apr 22, 2003 | 11:56 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I know from my PROM tuning experiences that what the gauge says and what the CTS sees can be nearly 15°F off.
WinALDL says my temp is 180°F and the autometer says it's 195°F.
Maybe this has something to do with it?
krisb410
Mid-Atlantic Region
Mar 11, 2016 09:21 PM
MoJoe
Sep 15, 2015 12:50 AM
86IROC112
Sep 11, 2015 04:04 PM
red rock
Sep 4, 2015 03:42 PM
Onefastcamaro
Oct 17, 2000 04:01 PM
