1999 into a 1989 w/in:
Old Jul 25, 2000 | 04:22 PM
Keithz's Avatar
Is it possible to put the heater and air condition controls of a 1999 camaro into a 1989 camaro? (Considering they both have heat and air conditioning)
thanks
Old Jul 25, 2000 | 07:42 PM
ZBRA's Avatar
Car: 1972 Corvette
Good question. I would be interested in info on this swap also.
Old Jul 26, 2000 | 09:56 AM
Keithz's Avatar
Anyone out there??
Old Jul 26, 2000 | 10:12 AM
SmokedU's Avatar
Good question.. id be very interested in this swap.. but you would have to get your hands on the controls of a 3rd gen and 4th to compare..
Old Jul 26, 2000 | 12:37 PM
Drew's Avatar
Probably not, the 99 system doesnt have the sliders that our setup has. The slider system MECHANICALLY drives a pushrod that opens and closes valves, and vacuum also plays a part in its operation. TO my knowledge the 99 system is all electric.
Drew
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3 @ 88mph
91 RS Convertible
92 S10
Old Jul 26, 2000 | 12:40 PM
Matt84TA's Avatar
It won't work. If you've ever seen behind the dash of one of our f-cars, they use a very complicated (and error prone) vacuum system that opens little plastic doors to direct air flow. The 99 camaro controls will not have provision for the vacuum lines.
Old Jul 26, 2000 | 01:37 PM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
Yes I think it could be set-up
What you will need is the Control unit and Programmer, and Electric heat/air exchange motor from a 99 f-body along with the wiring from the service manual.
I bet you could also get the Unit from a C4 Vette to work as well
I have an 89 vette. in the 89MY the vette had the manual and the electric AC. The manual uses sliders like the F-body. The Electric has an ECC(Electronic Climate Control), a stepper motor for the heat/air exchange door, and a Programmer. All the programmer does is take the electronic commands (voltages) from the ECC and operates relays which open and close Vacuum ports.
For some one willing to try it, it could work. the only thing with most of the ECC type systems is they have multispeed fans.. (more than 3 speeds) My corvette has 10 fan settings for the electric.. so you need to find one that will fit..
Good Luck
-=Jeff=-
89 Corvette Coupe White with Black Grand Sport Stripe
Check out my mods on My '89 Vette
Old Jul 26, 2000 | 02:26 PM
jptaylor2's Avatar
guys the swap can be made and does work but it requires extensive work to the firewall. there is a guy on here from holland i believe that put an entire 97 z28 interior in his 89 iroc. he put the dash,seats,console,door panels,air bags, and HVAC. i forget the site name but someone may remember. that car was the coolest camaro ive ever seen. he had the whole 97 drivetrain in the car as well. he had several pics of the HVAC install and he had to cut a huge hole in the pass. firewall. if i find the address ill post it here.
jptaylor
Old Jul 26, 2000 | 06:16 PM
ZBRA's Avatar
Car: 1972 Corvette
Too much work for such an insignificant change.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
wanext
Oct 6, 2015 12:18 AM
F-body-fan
Sep 17, 2015 12:16 PM
