edelbrock open elemtent
Old Apr 26, 2003 | 03:35 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
i'm installing an edelbrock pro flow open air filter, and after removing the single snorkle set up, there is some vacuum hoses left over, what do i do with them, and where do i put them? do i just plug them up? thanks.
Old Apr 27, 2003 | 12:43 AM
Dingley's Avatar
Engine: LG4 305
bump
Old Apr 27, 2003 | 09:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The correct solution is, DON"T USE THAT POS!!!! It will melt and get sucked into your carb, like it does on everybody else's cars that actually tries to drive around with it on there.
It's not a go-fast part at all. It's not even suitable for a car that runs. It's for people with all-chrome motors (like a 305 out of a 78 van or something), with a 6-71 blower (chromed), and all their brackets chromed, and chromed headers that haven't turned blue yet from starting up the motor, and polished and chromed dual Dominators, to have something chrome to stick on top of all that, so that 8-year-old boys can oooooh and aaaah over all the chrome as it's sitting parked in the parking lot next to other similarly chromed non-runnable cars.
Did I mention "chrome"?
Old Apr 27, 2003 | 09:44 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I think RB83L69 secretly worships an all chrome 400
Like mentioned proflow usually means the triangle of death. POS temp replacement when hood space is nil. The vacuum lines can be plugged, wont affect any part of operation.
Old Apr 27, 2003 | 10:24 AM
Dingley's Avatar
Engine: LG4 305
maybe i'm being unclear, i don't have the "triangle of death".. i have the circle open air filter.... very similar to the k&n air filter. anyways... you guys never answered my question...... what do i do with the unused hoses.
Old Apr 27, 2003 | 11:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The small hose that has vacuum on it, just plug the vacuum port; the large one, that went to the small filter, you should get the little kit they have available for installing into the air cleaner base, because that one supplies filtered air to the crankcase for the PCV system to keep your oil clean.
Old Apr 27, 2003 | 11:53 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ah the good old circle of death J/k.
You need a replacment breather, another chrome goodie. I dont like and wont use the adaptor to air cleaner base, they never fit correctly and always jiggle loose.
Old Apr 28, 2003 | 01:42 AM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
Most parts stores sell little rubber plugs that slide over the vacuum fittings. This is what I used when I went to an open element air cleaner.
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Scorched1984
Sep 15, 2015 03:42 PM
WickedBowtie
Sep 11, 2015 11:24 PM
toronto formula
Sep 10, 2015 07:31 AM
