WTF is going on here???
Old Jul 26, 2000 | 02:46 AM
SillyWabbit's Avatar
Car: '91 Formula
I step on the gas, my foot is off the clutch pedal completely, the car revs, but doesn't catch. Then after I let off the gas enough, everything catches and if I accelerate slowly, everything is fine. But as soon as I step on it again, same situation. And I don't even have to mash it to the floor for this to happen. This is like anything over quarter throttle at once. I was thinking it had something to do with TPS misadjustment, but that didn't seem to work for me. And I just gave the car a good tune up: coil, wires, plugs, dist. & cap, etc.... What's going on here?
Old Jul 26, 2000 | 02:57 AM
beattie1175's Avatar
Sounds like the clutch is fried and slipping badly. Time for a new one. Any probs changing gears?
Old Jul 26, 2000 | 03:15 AM
Car: '91 Formula
All the shifting is going fine as far as moving the shifer between gears. It's just that I step on the gas and it's like I'm in neutral.
Old Jul 26, 2000 | 04:27 AM
radiaki's Avatar
i have the same prob, exept i will accelerate pretty fast with the gas pedal ALMOST floored, but as soon as i push it all the way, even if i do it slowly, my car kinda SLOWS DOWN like i let OFF the gas? only in 3rd, 4th, and 5th gear? maybe my carb needs to be adjusted?
Old Jul 27, 2000 | 01:12 AM
Car: '91 Formula
BTTT. So does the clutch sound like a good bet?? Could it possibly be the clutch cable?
Old Jul 27, 2000 | 01:39 AM
zslug's Avatar
Can't be the cable 'cause there is no cable. 82-83 used mechanical linkage, 84-on is hydraulic.
Anything else going wrong would prevent the clutch from disengaging, the opposite of your problem.
Looks like you're replacing a clutch.
Zslug
May the road rise to meet your treads...
'84Z, 5sp, stock 305, Edelbrock intake, GTA wheels
Old Jul 27, 2000 | 01:56 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
My favorite clutch test:
Take off and shift from 1st to 3rd at a low speed and floor it. If the motor revs and it don't bog...you need a clutch.
ASE Mechanic/Machinist/Smog Tech
RTKTGTR 1999 NBM T/A, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
Old Jul 27, 2000 | 02:45 AM
Car: '91 Formula
Son of a beyatch. I could really go without this right now. Oh well. It might as well happen now when everything else is being replaced.
Old Jul 27, 2000 | 08:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Silly, the other guys are right, you need a clutch. Not what you want to hear, but think of it this way: you get the opportunity to improve your car a little. Get a Centerforce Dual Friction, it's smooth as silk when you are in bumper-to-bumper traffic, but hooks up like a piece of metal when you stand on it.
radiaki, the carb is a good guess in your case; sounds like the secondary air valve spring is too loose. Tighten it p in 1/9 turn increments and see if that doesn's help it.
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
