engine heating up abnormally quick
Old Apr 27, 2003 | 07:35 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i just got my 305 LG4 running after sitting for one year
the motor seems to heat up abnormally quick
i am not driving the car yet, i am just letting it sit in my driveway while i tune it
some clues i have to play with are: just installed long tube headers..........did not put on my exhaust yet, so i am running with open headers, i know the headers are supposed to heat up quickly, but not the entire engine
bad gas, i know, i know, i need to go and put some fresh gas in that isnt stale from sitting for a year
i set my edelbrock 600 CFM carb to idle at 800 RPM
could this be too high? i also have the idle mixture screws turned out 1.5 turns
i do not have my fan wired up yet, but i am not sure if this has anything to do with the problem, because as i said, the motor heats up very quickly
thanx
Old Apr 27, 2003 | 08:24 PM
breathment's Avatar
how quick is too quick?
Old Apr 27, 2003 | 08:41 PM
i did a search and i think i found the culprit, i need to switch my vacuum advance from manifold vacuum to ported vacuum and re-time my engine
pretty quick
engine gets pretty hot to the touch after a short period of minutes with out much load being placed upon it
i am thinking that is the problem though
Old Apr 28, 2003 | 10:22 AM
ok, i bumped down the idle to about 550 RPM and switched over my vacuum advance to ported vacuum seems to run much better now
if i run 93 octane (which i think i need to anyway) how much base timing should i be able to run?
Old Apr 28, 2003 | 04:32 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Distributor too far advanced/retarded?
Old Apr 28, 2003 | 05:32 PM
yeah, because i was taking the vacuum for my advance from the manifold rather than the carb
i switched it over this morning and she runs better
i also knocked the idle down a little bit to like 550/600 RPM
Old Apr 28, 2003 | 05:46 PM
Air_Adam's Avatar
Good to hear
BTW,what are the 305 4bbl carbs supposed to idle at?
Old Apr 28, 2003 | 06:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Good to hear
Sothing around 650/700 in N 550 in D.
The open headders especially long tubes in general create more heat in the engine compartment and do make the engine warm up quicker but nothing too noticleable. Unplug the vacuum advance completely when you time your engine. When you bump the timing up and idle increases it can suck through a ported source even though its not supposed to.
Infested
May 22, 2018 11:56 PM
NinjaNife
Aug 23, 2015 11:49 AM
happyhapka
Aug 15, 2015 04:42 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
