negative battery cable
Old Apr 29, 2003 | 05:02 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Where does the neg. battery cable go on a 90 350, TA ? I thought that it usually went to the block, but mine wouldn't really reach. I attached it to the bottom bolt that holds the alternator/power steering bracket to the front of the motor, this did not seem right to me but it is just the right length to attach here. Also I looked at another TA at the track and as far as I could tell that is where his went, his motor was bone stock and real dirty so it was hard to tell without crawling under the car with a flashlight, I didn't have a flashlight and couldn't fit under the car anyway. My motor was apart for awhile and I had labled and marked most stuff but not this, I guess I figured I would remember how it went. This is the serpentine belt setup with the huge A/C and alt. brackets.
Old Apr 29, 2003 | 05:32 AM
ede's Avatar
ede
long as it grounds about any place will work, not sure where it's suspose to go.
MM2Robinson
Oct 1, 2017 09:16 AM
Grant2k
Apr 4, 2016 08:21 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
