What would cause the steering wheel to hop????????
Old Jul 25, 2000 | 04:52 PM
Kyle F's Avatar
I had a new front suspension kit put on not too long ago(a PST set up). Well now when I hit about 60 or so the wheel starts to hop up and down. What would cause this. If I keep my hand on it IO can feel the vibrations, but it won't move. If I let go of it it starts hoping like maybe 1/2"-1" in each direction up and down. Any thoughts on this? Oh yea and its not loose at all I can't just set and shake it.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's
Old Jul 25, 2000 | 08:53 PM
Kyle F's Avatar
Back to the top
Old Jul 25, 2000 | 09:28 PM
Dr. Pepper's Avatar
Thats really bad. Can you move the wheel at all when the car is sitting still? I would think that the mounts or tilt column have come loose, but usually you can tell its always loose. I haven't had the column out of one, but I think there are a pair of bolts going up that help hold the column in. If those were to come loose it could move up and down.
Old Jul 26, 2000 | 06:55 AM
Kyle F's Avatar
No I can not move it when I am sitting still. I don't thin my tires need balanced and the front end just got lined up.
Old Jul 28, 2000 | 08:31 AM
MacEwen's Avatar
Car: 88 GTA
Engine: 350, 383
Transmission: T-56 & 700R4
Is the shaking increasing with speed?
Bad radial, bent rim, or unbalanced wheel.
I purchased rod ends from PST years ago. They had a bleed screw on the ends. I replaced the screws with set screws, because the heads of the bleed screws would scrape the rim, and remove any stick on weights placed near the inside lip the rim.
Over bumps?
Could just be your the input from the bushings, that you are not accustomed to. Are a bad centerlink, rod ends, or ball joint.
Ryan MacEwen Pruyn
MacEwen Motorsports
1987 GTA 350 6spd, White OEM instruments, 17" Borbet Type A's, 275/40ZR17's, 255/45ZR17's, Koni Sport Adjustables, Eichbach Sport Springs, Poly U, everywhere, Guldstrand Engineering Panhard rod, LCA's
Old Jul 28, 2000 | 08:43 AM
Kyle F's Avatar
Well I dont thin it would be anything on the front suspension. Might be a unbalanced wheel. I dunno. I bought the complete set up from PST so I doubt it would be any of the new parts. Thanks for your help I will check it out this evening.
Old Jul 28, 2000 | 05:40 PM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
Does it also shake when you brake? My rotors were warped and it shook at 70 mph and when I would brake. Try your rotors.
1985 Camaro Sport Coupe
LG4, 3.08 rear, A4
Bone Stock
1999 Blazer
4x2, 4.3L, 3.42 rears
Decidedly slow
Old Jun 18, 2002 | 12:17 PM
Patrick007's Avatar
My car did the exact same thing. The whole car shook. Turned out to be a combo of one bad ball joint and a broken tranny mount. Just something to check.
Patrick DeGrosse Jr.
Old Jun 18, 2002 | 12:30 PM
Damon's Avatar
There are 3 bolts that bolt the steering column to the firewall. If they are loose or not installed the wheel can hop around but you won't be able to move it just wiggling it from the driver's seat unless you really lay into it. There are also 2 bolts holding it to the dash support but if they were loose it would be obvious and you could move the wheel around easily from the driver's seat. Not for sure this is your problem but it's what casued a similar situation on my 91 Camaro.
Old Jun 18, 2002 | 08:41 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
anyone else noticed that this thread is 2 years old, and the starter is now banned?
Old Jun 18, 2002 | 08:46 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
What is ment my the Starter is Banned???and how did this come up he has not had that car in 2 years.
Brian
Old Jun 18, 2002 | 10:26 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
What that means is that the person who posted the thread originally has been banned from the site. He broke the rules, or did something that goes against the rules stated in the list that you read before signing up here.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
