Moroso oil pan ??
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Moroso oil pan ??
I have the Moroso 8 1/4 in oil pan on my 406. My question is . Will this be ok in my 89. Also, the seller claims it is an eight quart pan. All I can find that looks like the pan I have , says 7qrts plus the filter. It has a melling pump with a stock style P/U welded on...is this ok with this pan? He included a moroso 8 1/4 p/u that is new in the package... doesnt look like it sits any lower...should I use it or keep the current set-up? Do the Moroso pans have a part # on them somewhere? How can I be sure wich pan i have?(capacity)..this is what it looks like....I can take some pics of it if you need, but it looks like this one.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
What headers are you going to run..that pan may be in the way.AFAIK Moroso pans have no part number on them..it's been awhile since looking at mine.I would recommend a pan like the #20180..it is 7 quarts with filter..I have had this one for four years now with no problems..even fits my SLP 1.75" and Y pipe.I usually run it a quart low..6 total to try and help reduce windage in the pan.
