new slave cylinder question
Old Jul 30, 2000 | 02:01 PM
87-305's Avatar
i just put in a new slave cylinder for my clutch, but the pedal still shows little resistance. can i cut the tiewrap myself, or does it need to be broken itself. could there be another problem? how will i know if the master cylinder is bad?
Old Jul 30, 2000 | 02:47 PM
87-305's Avatar
please please please help, i have to go to work in 2 hours. the tiewrap popped and the pushrod came out, but then i think something happend, because the pedal is loose again, but there are no leaks
Old Jul 30, 2000 | 02:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am not aware of your other posts so from the start did you bleed the system a gain? it may take some time to get all the air out of the new slave.
Old Jul 30, 2000 | 02:58 PM
87-305's Avatar
how exactly do i bleed the system? maybe i am doing it wrong. my clutch pedal had no resistance and i found the slave to be damaged so i replaced it and at first couldn't get the tiewrap to pop off. but the alan screw just wasn't tightend enough, and when i pressed the pedal again it had resistance and then it made a pop noise and the resistance was gone again. please help
Old Jul 30, 2000 | 03:00 PM
87-305's Avatar
if the cylinder isn't bleed will the pedal have free play? i'm just trying to figure out if bleeding has anything to do with it. how do you know when you need to bleed the system
Old Jul 30, 2000 | 03:13 PM
87-305's Avatar
what is the pushrod supposed to be doing? it isn't moving when the pedal is pressed
Old Jul 30, 2000 | 03:22 PM
Engine: ls1, LB9
make sure you have every thing connected.(bolted to the bell housing) strap cut off you can leave the plastic tip on just have the plasic straps cut. then have the resivor full well up to its fill line then have one person slowely push down on the pedal and you open the bleader screw when they get the pedal to the floor have them hold it till you get the alen screw tight.(not over tighten it is a plastic case and will strip quite easy.)then tell them to release and keep repeating till it has no more air coming out your end. (check the resivor several times)
Old Jul 30, 2000 | 03:50 PM
87-305's Avatar
i did that and i think i stripped the screw. thanks for your help. it looks like i'll have to start over again
Old Jul 30, 2000 | 03:54 PM
Engine: ls1, LB9
I did the same thing when I did mine but, I lucked out and it only happened to the original one that was leaking any ways.
Old Jul 30, 2000 | 04:02 PM
87-305's Avatar
should I just buy a new slave cylinder?
Old Jul 30, 2000 | 04:09 PM
Engine: ls1, LB9
if you striped the one you have. how did you decide the first one was bad??
87-305's Avatar
ok, on a hydraulic clutch that is working what exactly happens between the pushrod and the fork?
Old Jul 30, 2000 | 04:12 PM
87-305's Avatar
i was driving my car and it snapped when i pressed in the clutch i looked under my car and the slave cylinder was draining out the fluid. how do you know when the fork is bad?
fasteddi
Sep 2, 2015 10:29 AM
KO1
Aug 31, 2015 06:31 PM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
