Which 1st, SLP Headers or Cat-Back?
Old Jul 31, 2000 | 12:05 PM
carey91z1le's Avatar
I've wanted SLP headers for a while and now that they are $350 it seems like a good time. My question is should I get the headers first or a cat back system. I've got a 91 1LE (L98) with the stock setup. I don't have the cash now for both, so what should I get first?
-carey http://members.aol.com/briscuso/camaro/
Old Jul 31, 2000 | 01:32 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You c ar should have a decent CB from the factory...I'd opt for headers first.
Old Jul 31, 2000 | 07:56 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'd get the headers now since they're more expensive and on sale. Cat-backs are pretty inexpensive.
1991 Camaro Z28
5.7L 5-Speed
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Webmaster: ICON Motorsports
Old Jul 31, 2000 | 10:43 PM
fredo92's Avatar
Car: 92 Camaro RS
Hey, I would actually suggest getting the cat back first believe it or not. I put headers on my camaro before I redid the rest of the exhaust and It kept blowing donut gaskets out of the collectors due to the increase in backpressure in the system. The average life of one was about two or three days. I replaced the rest of the exhaust, and I haven't replaced a collector gasket since, and it's been about a year now. So I would definitely suggest doing the exhaust first.
'92 RS convertible with 305/700r4, slp headers, 3" high flow cat, 3" flowmaster w/2.5" outlets/hypertech chip, k&n open element, "modified" eibach springs, kyb shocks&struts, and polygraphite bushings.
Old Aug 1, 2000 | 12:17 AM
Kevin91Z's Avatar
I should have said to just get the headers now since they're on sale. You dont have to install them right away. Get the cat-back later and put them on at the same time. It'll be more expensive all at once to put them both on, but it'll be cheaper than paying twice.
1991 Camaro Z28
5.7L 5-Speed
13.25 @ 107.18 MPH
Southern California
Old Aug 1, 2000 | 03:32 AM
88IROCs's Avatar
Consider the true cost of the headers(this is from my own SLP invoice):
HEADER 1-3/4 4to1 82 CAM/FB 1CAT W/AIR.... 349.95
INSTALL KIT, HEADER 88-92 CAM/FB 1CAT....... 68.00
ADAPTER, 3" SLIP CATALYST, BOXED............. 29.95
'''''''''''''''''''''''''''''''''''''''''''''447.90
Then consider most other headers, include all of the above for less money. And they are probably better constructed than the POS headers SLP sent me.
But I'd agree with getting the catback first. Putting headers in front of the stock catback will definitely increase backpressure, which <U>ALWAYS</U> hurts power. A good-quality catback will net you 15 hp, but the headers will only get you 10.
One final reason for going with the catback first. Unless you're a silly-assed fool(like me ), and insist on a Borla catback, the catback will probably be cheaper than the headers.
He who hesitates,... is lost!
Old Aug 1, 2000 | 09:29 AM
Mike 25th's Avatar
Just FYI... I am in the middle of putting SLP's on my car and WTF??? I'm having one hell of a time getting them in. Luckily my car is in 100 pieces at the moment. You might have an easier time because yours is a 1LE - less crap under the hood. But I'd get SLP's over anyone else. They's last a lot longer in my oppinion.
Old Aug 1, 2000 | 09:43 AM
Bob R's Avatar
I just finished installing the SLP 1 3/4" headers on my 89 IROC L98. It was no picnic! A heads up for you is to put new motor mounts in first. You are going to need all the clearance you can find with the 1 3/4" setup! It ended up being a 8-10 hour job!! ! I second doing the Cat back first.
Bob R
(ROCN-Z)
89 IROC L98
Old Aug 1, 2000 | 10:23 AM
Steve89Formula's Avatar
Not to be-labor the point, but consider the "true cost" of the SLP headers before they ran the special. $479.95 + $68 + $29.95 = $577.90!!! And, considering that most other headers run from $310 to $370 and are NOT 409SS, I'd say the SLPs are a true steal. In fact, just placed my order!!!
Old Aug 1, 2000 | 02:57 PM
Kevin91Z's Avatar
If you think the SLP headers are a piece of poop, you should see what the Edelbrock's look like out of the box! *spit* Putting headers on our cars is a pain in the *** , there is no way around it. Just grin and bear it.
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
alpine247
Sep 16, 2015 05:25 PM
scottmoyer
Sep 7, 2015 07:06 PM
